Tip & How-To about Plantronics Voyager PRO Bluetooth Headset
Plantronics voyager pro battery replacement
This is not a difficult replacement but it is small inside the headset. you will need an exacto knife and a soldering iron. Take a look at the video and I will give you some good tips.
Plantronics Voyager PRO  Bluetooth Headset Logo
removing metal wrist strap casio gw-3000bd
With most watches, use an Exacto knife to compress the pin to remove it. Replacing the pin is more difficult.
Nov 13, 2014 | Casio G-Shock Tough Solar GW-3000BD-1AJF...
how to replace kitchenaid superba light bulb
The light bulb on the water/ice dispenser on our Kitchenaid Superba side by side refrig needs replacement. Easy! Right?
However it is screwed in so tightly and the location is behind the panel is so small, it it very difficult to get a grip on it to unscrew it!
We,ve tried rubber gloves, WD-40 and an Exacto knife(w/ fuse turned off!) and still cannot get this very annoying light bulb out!!
Does anyone have any ideas or can we remove panel it hides behind to get to it!!!???
Thanks for any info on this should be simple issue!!
Susan M
Jan 15, 2012 | KitchenAid Superba Architect KSCS25INSS...
jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
tshow me how replace ir sensor on toshiba tv 61a61
Please find above your service and repair manual, inside it shows you everything you need to know to accomplish this.
It is NOT a difficult task. BUT you will need a soldering iron on some sub chassis. Others use a plug and Wire, and one simply unscrews the old, unplugs from the sub board and replace. Other ones are soldered to a sub board, and need to be removed with a soldering iron. Either way it's a doddle. (Easy to do)
Aug 25, 2010 | Toshiba 61A61 61" Rear Projection...
140 people viewed this tip
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
