Tip & How-To about Miscellaneous
Peugeot 206 cc nice car but parts expensive
If your back windows on a Peugeot 206 cc stops working, don't panic, and most importantly don't take it to Peugeot.
Simply remove the top cover, and side panel, you will have to remove the two nuts under the seats, to loose them , and release the back rest.
After you have acess to the inside, where your window regulator sits, take a look at the cable and the clip. Normally the white clip that holds the cable by both ends brakes and then the cable gets tangled. Order the repair kit from Bross auto parts via Amazon, costs between US$15 and US$20, it comes from Turkey, and I am in South
Africa, so ti was a pleasure to get the cable repair kit 3 days latter. I you a sort o DIY you can save about US$200, on my case I saved over ZAR3500. Good Luck
Miscellaneous Logo
how do i find part number for window regulator clip for rear left Window
Should be a 5 minute task at your nearest dealer. The clips will be genuine part only. Take your VIN number in with you.
Feb 23, 2015 | 2006 Peugeot 206 1.4
i have a peugeot 206 cc and the boot sensor says boot is open when it is closed
central locking isnot working because the boot cant lock change the boot sensor wswitch then central locking will work all good
Aug 19, 2012 | 2004 Peugeot 206 CC
2003 PEUGEOT VIVACITY VS/X speedometer stopped working
Hi, Chad_uk for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
206 cc Speedo not working
How to FIX For Scooter Speedometer and odometer Stopped Not Working
PEUGEOT Vivacity Workshop Manual
Peugeot VIVACITY 50 cc 1999 Parts
PEUGEOT Vivacity Owner Manual
Apr 18, 2017 | 2007 Peugeot Vivacity 50
peugeot 206 cc fan belt change
hi ive a peugeot 206cc 02 reg, the STOP light keeps flashing ive checked the normal oil and water but alls ok so whats the problem still runs fine and temp stays where it should??? any tips??
Aug 28, 2009 | 2005 Peugeot 405
42 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
