Tip & How-To about Home
What vinegar to use for cleaning?
If you want to green clean your home with vinegar, the best one is white vinegar, because it won't color your textiles (in case you use it for stain cleaning). If you're not sure how to do it, or you don't have the time, I recommend the experts for Carpet Cleaning in SW11 Battersea
Home Logo
My Russell Hobbs RH1042 5Kg White Washing Machine won't intake softener when I put a wash on, it just stays in the drawer. It is brand new so won't need cleaning out? Can anyone help?
have done all the cleaning with toothbrush ran the machine on a boil wash frequently on empty bought all the washing machine cleaners used white vinegar soda crystals all to no avail not taking fabric conditioner and the filter at the bottom of the machine after each wash filling up with water at my wits end any help please
Aug 17, 2012 | Washing Machines
dishwasher leaves grit on dishes even after a full wash
Most likely need to clean your dishwasher. Yes....clean the dishwasher. Hard water builds up scale in them, and the best way to clean them is with a product called "Lemi Shine". It's actually just citric acid the same as you find in oranges and lemons, but in this case you put it in the dishwasher and run it empty. It cleans off the scale and deposits that have built up in the tub, pump, and wands. You can do the same thing with a quart or so of white vinegar, but it would take a few times to get rid of the smell. The Lemi Shine smells like lemons, so you won't need to worry about it after you use it.
Best wishes, and thanks for using FixYa!
May 03, 2011 | Kenmore Dishwashers
What is the best home remedy to clean a bunn?
With the machine turned on and hot, pour in 1 quart of white vinegar and close the lid. Let the vinegar sit for 2 hours. Then flush out the machine with 8-10 decanters of cold water.
Oct 10, 2010 | Bunn 10 Cup Home Coffee Brewer
What is the best product to use to keep these floors clean?
a very mild solution of white vinegar and cold water, with a thick sponge mop and large pail for the water....pass 3 times as wash...and 2 times as clean rinse mop water only....vinegar alos sanitizes and the citric acid cleans naturaly....
Jan 24, 2010 | Venture Shock Athletic Ultra Flex 16pc....
Steam iron residue on suit pants
I would send them to the drycleaners and point out the contamination. If they were mine, I would treat them with a little white vinegar; the white deposits are caused by a buildup of calcium in your iron. Don't put the vinegar directly on the trousers but use a clean cloth with some vinegar on it and gently massage the deposits.
It may stink, but it is wise to now and then run it warm (only) with some white vinegar which will dissolve the deposits. Put it on a heat-proof surface (such as a stove grate) so it can stand flat otherwise not all of the deposits will get soaked with vinegar. After letting it soak warm, run several tanksful of plain water to remove the vinegar and shake it over the sink in case there is chunks (very well could be) that have been loosened.
Mar 27, 2009 | Rowenta DG-980 Iron
82 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
