Tip & How-To about SWANN Home Security
Swann wireless cameras will not connect to the cloud after the recent update.
Uninstall the Swann app from your mobile device.
Use a pc or laptop and log into your network connections and navigate to wireless password settings and change the password for the network that your problem camera connects to. This will keep your camera from auto connecting. You will add them back later.
Restart your router. When the network is back online log in again , and confirm that cameras are no longer connected. You do not have to power the camera off.
NOTE: (You will have to repeat the following steps for each camera. Do not use the same qr code on more than one camera)
Open a browser window and navigate to the Swann cloud website. (https://www.swann-cloud.com) and log into your account.
Navigate to the camera tab and check to see if your cameras are in the camera list. Delete all non working cameras from the list and log out. (As a precaution, you should download any events that you want saved to prevent them from being removed. Or only remove one camera at a time when you are deleting cameras).
Reboot your pc or laptop and log back into the website and navigate back to the camera tab and select
Select the option you prefer. (Usually wifi unless your camera is plugged directly into your router wired option is useless)
Enter your wifi logon and password
You should now see the qr code with two options. Select for the old qr code. It should automatically show the highlighted and display a qr code.
Using your cell phone, open the camera and take a clear picture of the qr code, make sure that the picture of the qr code fills the screen so it isn't too small.
Locate the picture in your photo gallery (I recommend that you crop the picture so that only the qr code is visible)
NOTE: Do not log out of the Swann cloud website or close the qr code window from here, it must remain open. Leave the qr code on the screen.
Home Security Logo
i just switched to a different internet provider. Alexa says she is having trouble connecting. What should I do?
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
Jan 25, 2017 | Internet Computers & Internet
Need to update drivers on my Toshiba a135 s4527 it wont wirelessly connect to my ciscodpc3825
Reset your network, and restart the laptop. Get a network cable (CAT5) and connect the laptop to the router with that and download THIS PROGRAM, and install it. It is free and I have used it and trust it. Run it to update your drivers. Make sure your wireless adapter in the laptop is turned on. If it still won't connect, uninstall it from the Device Manager, and reboot. Go back to the Device Manager, and make sure it has been reinstalled, and make sure it has no Exclamation mark or and X. Is should work, if it is turned on. Use your WiFi network password to log in. Post back with any further results, please.
Jul 22, 2013 | Computers & Internet
i lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
we cannot log on with the assigned password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
hope this helps
Dec 30, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
I have forgotten my security key for connecting to the internet with my netgear wireless router
hope this helps
Nov 11, 2010 | NetGear Wireless router EN Fast EN
84 people viewed this tip
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
