Tip & How-To about Miscellaneous
Stainless Steel 316 Pipe
Stainless steel type 316 is part of a family of stainless steel alloys (304, 316, 904L). The 316 family is a group of austenitic stainless steels with superior corrosion resistance to Stainless Steel 304. This alloy is suitable for welding because it has a carbon content lower than 301 to 303 series alloys to avoid carbide precipitation in welding applications. The addition of molybdenum and a slightly higher nickel content make Stainless Steel 316 Pipe suitable for architectural applications in severe settings, from polluted marine environments to areas with sub-zero temperatures. Equipment in the chemical, food, paper, mining, pharmaceutical and petroleum industries often includes Stainless Steel 316.
Stainless Steel 316 pipe manufactured at Duplex Supply Inc. are long, hollow tubes that can be used for a number of purposes. They are an integral part of the piping systems. The first methods for producing steel pipe were introduced in the early 1800s, and they have steadily evolved into the modern processes we use today. Pipe systems around the world involve connections which are provided by fittings. Steel pipes are consumed in bulk and provide for onward transmission of liquids and gases. They can be connected to fittings by welding and the structure is supported by connection of flanges. Steel pipes available in two types: Seamless Steel Pipes and Welded Steel Pipes. For both types we first cast raw steel into a more workable starting form. We then make it into a pipe by stretching the steel out into a seamless tube or by forcing the edges together and sealing them with a weld.
Stainless Steel 316 Pipes Duplex Supply
Miscellaneous Logo
What is the role of stainless steel products?
Products which are manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do. On the other hand, if it is hardened stainless like what is used in instruments, you probably will need carbide, although you might get a tool steel drill to make one hole.
Stainless steel is defined as a steel alloy with a minimum of 11.5 wt% chromium content. Stainless steel does not stain, corrode or rust as easily as ordinary steel, but it is not stain-proof. It is also called corrosion resistant steel when the alloy type and grade are not detailed, particularly in the aviation industry. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Common uses of stainless steel are cutlery and watch straps.
For detailed information visit at: Solutions of Stainless Steel Products
Feb 01, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
what is the name or number of nonmagnetic stainlessteel ?
It is commonly stated that "stainless steel is non-magnetic". This is not strictly true and the real situation is rather more complicated. The degree of magnetic response ormagnetic permeabilityis derived from the microstructure of the steel. A totally non-magnetic material has a relative magnetic permeability of 1. Austenitic structures are totally non-magnetic and so a 100% austenitic stainless steel would have a permeability of 1. In practice this is not achieved. There is always a small amount of ferrite and/or martensite in the steel and so permeability values are always above 1. Typical values for standard austenitic stainless steels can be in the order of 1.05 - 1.1. SeeComposition effects on the magnetic permeability of austenitic stainless steels
It is possible for the magnetic permeability of austenitic steels to be changed during processing. For example,cold work and weldingare liable to increase the amount of martensite and ferrite respectively in the steel. A familiar example is in a stainless steel sink where the flat drainer has little magnetic response whereas the pressed bowl has a higher response due to the formation of martensite particularly in the corners.
In practical terms, austenitic stainless steels are used for "non-magnetic" applications, for example magnetic resonance imaging (MRI). In these cases, it is often necessary to agree a maximum magnetic permeability between customer and supplier. It can be as low as 1.004.
I hope this helps you
Jun 19, 2014 | Measuring Tools & Sensors
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Feb 17, 2012 | KitchenAid KSF26C6Xyy Side by Side...
Rust spots appearing on the front doors of my Bosch refrigerator
Stainless steel does rust - or at least that is the theory.
There is in fact two types of stainless steel; the original categorised austenitic which is instantly recognised due to it being unable to attract a magnet due to the absence of iron. Austenitic is relatively expensive and difficult to work but adding iron in various quantities to the alloy produces a cheaper, lighter metal that looks good and is easier to work while still providing some resistance to corrosion. The more iron that is added to the ferritic type of stainless, the lighter, cheaper and easier it is to work but the corrosion resistance is substantially reduced.
Cars have been fitted with stainless steel exhaust systems of the ferritic type for many years and although they last a long time they soon show surface rust and sometimes will rust through.
I expect your fridge wipes are either acid or alkaline that are suitable only for austenitic and good grades of ferritic and Bosch have used a particularly poor grade of stainless. I expect fridge magnets stick very well...
Mild discolouration could be removed with a mild abrasive cleaner though that would tend to ruin the brushed finish. Clearly future cleaning should be carried out with a neutral ph cleaner and the surface protected with a hard wax polish.
I suggest you check the cleaning instructions in the Bosch instruction book. If you feel you have done nothing wrong you might be able to claim from your household insurer as accidental damage. It would be a good idea to inform the manufacturer of the cleaning wipes...
May 27, 2017 | Bosch B26FT70SNS
stainless steel?
There are many (>100) standard stainless steel alloys. The most commonly used stainless steel alloys in appliances are "austenitic" - these have a higher chromium content and added nickel. The nickel modifies the physical structure of the steel and makes it non-magnetic.
Nov 04, 2007 | Kenmore 15073 Stainless Steel Built-in...
62 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
