Tip & How-To about Boating
Safe practice on my boat
When I have passengers on my boat each has a chore to do in the event of an emergency my chore is always to grab epirb
, next passenger has chore to grab safety bucket which has flares & more
next passenger is to grab the Eski or cooler as it always has drink in it
so on & so on
they also have to be aware of grabbing their own life jackets too.
Boating Logo
Which passenger grab rails fit on a Vstar 1100?
Hi, Anonymous I believe that part number is 91583-99 retail $130 for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Passenger Grab Rail
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
OEM parts for Yamaha
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
Apr 10, 2016 | 2005 Yamaha V Star 1100 Classic
Need personnel Capacity for 1989 Wellcraft Sportsman 250.
go on line to google -type in seating capacity of wellcraft 250 and under southport-freedom boat club you will see a passenger capacity --6
Dec 27, 2014 | Cars & Trucks
does it matter what wheel you bleed first on a kia sedona 2002. I have told by a friend to bleed the passenger rear 1st the driver rear then passenger front then driver front is that right.
When bleeding brakes always start at the furthest point from the master cylinder. So start at the passenger's rear and then the next furthest point, the driver's rear, then passenger front and last driver's front. Hope this helps.
Sep 19, 2010 | 2002 Kia Sportage
ingene cranks but wont start. checked fuses and relay are ok, fuel pump has no power.
open the bonnet/hood then if you look on the passenger side of bulkhead next to inner wing there is a fuel emergency fuel pump shut off switch it is square and has a press button also on top usually rubber coated it may be red or yellow in colour ? try pressing button then try starting ? this switch is auto operation and switches off power to fuel pump in event of impact /accident so lessens risk of fuel leakage and possible risy of fire ? have had these trip out with older vehicle by simply dropping hood closed worth a try ?
Mar 02, 2010 | 2001 Hyundai Accent
How do you move the bench seat forward? It seems
There is a cable running from the lever to the latch on the passenger side and it has stretched. Feel around under the seat and you should be able to grab hold of it.Give it a yank after you have pushed the lever and it should release, letting you move the seat. I don't know if it's replaceable but you could use an emergency brake cable adjuster to shorten it so it would work. Hope this helps.
Oct 18, 2009 | 1997 GMC Sonoma
76 people viewed this tip
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
