Tip & How-To about Furniture
Restoring antique furniture sympathetically
If you have unpainted antique furniture, please don't sand it to restore it if you do you remove all the years of gentil removal of the soft timber that has gone& the result is you sand all the hard material that is now raised this is called patina, the result is a piece that now effectively looks like new may as well have a reproduction piece. To do a sympathetic restore buy some steel wool which you can buy in different grades fron 000-3 or 4 being the most course, use metho & thinners 1/2 & 1/2 to remove the old shellac or varnished effect, drying it off wth rags as you go, finally wipe over wth just metho to get it all real clean then once totally dry maybe the next day either wax or French polish to Finnish off.
my personal opinion is there are some real nice waxes out there that not only look good but smell wonderful.
just a footnote make sure you use the steel wool in the direction of the grain, if you go against the grain you will scratch the timber & it takes a lot of work to bring it back. Good luck with your next restoration.??
Furniture Logo
how do I paint furniture? I know I have to sand it first.
easy stuff. sand it lightly and go for it. may need two coats
Aug 27, 2017 | Furniture
Restoring flooded furniture
Paula, You may have to sand vanity all down so stain can be applied to cover water staining, if water stains/damage does not sand out easily. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Get Water Stains Off Wood
Jun 26, 2016 | Furniture
headlight lense covers faded how do you remove them
John- You don't remove them, you sand then with 1500 wet or dry paper, then polish them with white compound and a light application of the buffer. BE GENTILE!!!. Each new headlight assy is about 50-100 bucks EACH!!!
paper and compound is much cheaper!
Nov 30, 2011 | 1996 Chrysler Sebring
67 people viewed this tip
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
