Tip & How-To about W87-Rh-P Rapide Ultimate Clean Upright Carpet And Upholstery Washer
Clean a Carpet Stain with Baking Soda
You can deal with every stain that appears on your carpet if you keep calm and act quickly.
Step 1: Grab a white towel and gently take away the liquid.
Step 2: Pour some baking soda on the stain.
Step 3: Leave it for a few hours.
Step 4: Rinse out the surface with a calm water and white towel.
If this doesn't work, call the experts at 1st Carpet Cleaning.
Steam and Dry Rug Carpet Cleaning Company Anerley SE20 1st Carpet Cleaning...
W87-Rh-P Rapide Ultimate Clean Upright Carpet And Upholstery Washer Logo
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
How to get almost ANY stain out of carpet! WITH ONLY WATER
Just go to Home Depot and buy Folex...it is handsdown the BEST stain remover I have ever come across and the cheapest, ecofriendly also and you can use it on just about anything, laundry, car carpets, amazing stuff....they have a website too!
May 18, 2010 | Cosco Juvenile Scenera Convertible Car...
how to clean suede chair cover?
  • 1 Remove dust from suede by rubbing with a terry cloth towel in a circular motion.
  • 2 Rub smudges, dirt and dried stains with a pencil eraser. Good Housekeeping recommends using a kneadable eraser (available at art supply stores).
  • 3 Sand matted areas by briskly rubbing them with sandpaper or an emery board. This will restore some of the original texture.
  • 4 Dip the towel in white vinegar and gently dab any remaining stains. The suede should appear a slightly darker tan while damp, but not muddy or gray.
  • 5 Allow suede to air dry.
  • 6 Massage the entire surface of the fabric in a circular motion with a suede brush or toothbrush to reestablish a velvety grain.
  • Mar 05, 2013 | Health & Beauty
    cleaning spots on carpet my pet throws up on carpet
    Robert, I take care of that problem two ways. First I take a very wet cotton towel and put it in the microwave for about 1 minute. After that time I remove it while wearing a GOOD pair of gloves, as you are dealing with steam. Go to the spot and rub the heck out of it with the cloth. You may have to repeat, but do NOT forget the gloves. Also, there is a spray bottle product of a cleaner called Awsome. I find it helps clean these spots as well.
    Aug 27, 2010 | Vacuums
    87 people viewed this tip
    Top Vax Vehicle Parts & Accessories Experts
    Bigaitch
    Level 1 Expert
    seanwalters1
    Level 1 Expert
    David Grady
    Level 1 Expert
    Are you a Vax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
