Tip & How-To about Miscellaneous
Prevent streptococcus
This bacteria is the main cause of Strep Throat, Pharyngitis etc. Always keep your mouth clean . Brush regularly. See that thing bacteria doesn't grow in your mouth. Hygiene is the key to avoid streptococcus. Can You Get Strep Throat Without Tonsils Wisledge
Miscellaneous Logo
what cause bad breath and what to use for it?
There are about 600 different types of bacteria living in your mouth, and they create a lot of different smell. The common reasons come from: dry mouth, diet, smoke, or other diseases like sinusitis, tonsillitis, pharyngitis.
There are some natural remedies you can follow at home which are easy to apply by using some ingredients like: fennel, cinnamon, cloves, lemon juice,...
To know how to use them effectively, consult at: Home Remedies For Bad Breath Authority Remedies
Sep 22, 2016 | Health & Beauty
Can you avoid getting a sore throat?
The answer is yes. You should try to gargle your throat with some green tea because it can kill some bacteria and soothe the throat tissue.
Here is the article that I think It might be helpful for you
Home Remedies for Sore Throat Authority Remedies
Feb 18, 2013 | Health & Beauty
How can I avoid gum diseases?
Preventing Gum disease is important for your teeth. Here I will tell you some simple steps to get rid of Gum problem:
Brush and floss: The best way to prevent gum disease is to brush and floss regularly, which eliminate bacteria at the gum line and between teeth without harming the gums themselves.
2. Go for regular Teeth check-up:
It will prevent you from the up-coming Gum problem.
Stop smoking: Smoking decreases circulation, not allow to keep gums healthy, and it's also a primary contributor to gum disease.
Chew sugar-free gum: When you can't brush after a meal, chewing sugar-free gum can help promote the production of saliva so tiny food particles can be cleared away and your mouth's healthy environment can be restored.
Feb 03, 2013 | Health & Beauty
86 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
