Tip & How-To about Computers & Internet
Knowlegde is obtained not bought
Always be willing to learn at any cost
Computers & Internet Logo
will ignition control module affect manifold an cause loud noises
Hi David,
Here is a good explanation. 360 Look Into the GM 60 3 1L Engine Underhood Service . Repair Pal is a forum for questions like yours with many good answers, Oldsmobile Cutlass Ciera Repair Problems Cost and Maintenance. But yes to your answer, isolate, and eliminate. I always like you learn more so the out of pocket becomes less. Fare. Well.
Jul 05, 2014 | 1989 Oldsmobile Cutlass Ciera
ENVISION EN-7100SI LCD MONITOR-WHEN YOU TURN IT ON IT FLASHES NO SIGNAL THEN GOES BLACK .IVE HEARD YOU REPLACE A CAPACITOR AND IT COST ABOUT TWO DOLLARS I HAVE TO OF THESE MONITORS BOTH THE SAme exact problem.can you help? TIM CHALOUX TACHALOUX@AOL.COM
First, if it shows no signal because it is not receiving the signals from PC then it will go into stanby mode. Try it with another PC first and also check the cable.
Most capacitors kit costs around $15 if you replace them in a set, I always replace them in a set.
Learn more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Post back what you find.
Dec 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
91 people viewed this tip
David Payne
David Payne
