Tip & How-To about Breville YouBrew 12 Cup Thermal Grind and Brew Coffee Maker
How to fix coffe maker when it is not making the required amount of cups
If you coffee maker is not making the requested cup amount and their is steam and water dripping from top of the basket area ,the water tube check valve may be plugged. You can unplug unit and remove the eleven screws at the bottom of the coffe maker and access the tube coming from the water tank. Remove the tube, and clean it out under water tape and blow into it . This should dislodge the calcium build up and reassemble. Be careful not to loose the long spring that is inside the tube. Check out link to my video on this. Breville You Brew Coffee Maker Repair
Breville YouBrew 12 Cup Thermal Grind and Brew Coffee Maker Logo
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
why does coffee come out while pouring in water its a bunn 10 cup coffee maker
The Bunn has a little stopper that closes the water drain port in the reservoir while the lid is open. You can see a little white plastic pin protruding up out of the grate with the lid open. When you close the lid, it pushes on that pin which causes the stopper to lift off the drain port, allowing the water in the reservoir to enter the heating tank.
If water is entering the coffee basket BEFORE the lid is closed, then something is wrong with that little stopper. It may have a chunk of debris on it preventing it from sealing, or it may be deteriorated, torn, disconnected, etc.
Only way to know is to remove the the screws in the grate and pull the top off exposing the reservoir, and the stopper assembly. The little plastic flapper disc should be seated in the reservoir drain port. It should be relatively flat (not wrinkled) and covering the drain port completely. Test it by pouring some water into the reservoir. If it drains out without you activating the stopper, then a repair is needed.
Move the lever up and down and check its operation. The arm must move freely and close when released. There should be no dirt or debris on the sealing surface of the flapper nor on the sealing surface of the drain port. Gently clean with vinegar as necessary. If the seal is damaged, then a replacement is required.
Nov 29, 2014 | Bunn 10 Cup Home Coffee Brewer
how to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Not getting all the water
Faulty check valve inside the tubing at the bottom of the unit. This is the tubing conveying water from the outlet of the tank into the heater coil prior to going into the coffe basket.
I have the same problem but cannot find replacement check valve.
Feb 16, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Need owner's manual for a West Bend 57870 coffee maker
Manual Not Listed On Website, but Information on Coffee Amount is.
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2318&secid=54&linkon=category&linkid=21
Coffee Amounts
How much coffee should I use?
4-Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. You can adjust the amount to suit your personal preference but DO NOT USE MORE THAN 2 TABLESPOONS per cup being made. If more than 2 tablespoons per cup are used flooding of the basket may occur.
10 and 12 Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. If making less than 4-cups of coffee, add an extra tablespoon of coffee for better flavor. You can adjust the amount of coffee used to suit your personal preference.
Dec 28, 2008 | West Bend 56870 Coffee Maker
173 people viewed this tip
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
