Tip & How-To about Pool & Spa
How to solve Salt Water Pool Problems
Salt Water Pool - Friend or Foe?
Salt water pool systems are extremely popular but that does not mean they are not without problems that some people find outweigh the benefits... that is until now. See today's breakthrough video and learn how you can enjoy all the benefits of salt water pools without the drawbacks, problems, hidden expenses, and potential dangers.
See Today's Salt Water Pool Breakthrough Video:
You can learn more about this system at: Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Pool & Spa Logo
Can I use pool salt in my summer escapes pool?
if you have a salt system add salt but you have to shock pool to get it clear
Jun 09, 2014 | Intex Automatic Salt Water System for ...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
107 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
