Tip & How-To about Acer Computers & Internet
How to check if you laptop screen has gone out
Turn on the laptop, if fan is running and the lights that normally work are working.
shine a bright light on the screen if you see a low lit display the screen is fine.
Its either your Backlight or screen inverter which provides the power to the screen.
Computers & Internet Logo
I have a acer aspire 5720 and I went to turn it on and it turns on but nothing at all comes on the screen
If the fan runs and the keyboard lights up with hard drive noises, the screen is probably faulty. Shine a bright light at the screen, that will tell you if the inverter has failed or not as if you can see something in the background, the screen is OK it is the inverter.
Nov 08, 2013 | Acer Aspire Computers & Internet
L35-S2171, Monitor screen will not light up. Screen is new, inverter is new. I can see images when I shine a flashlight on the screen. The rest of the computer works just fine. What is the fix for this problem?
might be ur LED 's r fused up..
try to increase the brightness from ur keyboard.. might be ur screen light is turned off..
try to increase the brightness via ur function key & additional key on keyboard...
hope dat works out
Nov 29, 2009 | Computers & Internet
WHEN BOOT UP ON MY ACER ASPIRE THE SCREEN REMAINS BLACK, IS THERE A SOLUTION TO FIX IT?
if you have the restore cd for you computer run it and follow the directions,, if not thats it repair shop
Aug 11, 2009 | Acer Aspire 5610-4648 Notebook
dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
211 people viewed this tip
Mohammed Ebrahim M
Mohammed Ebrahim M
