Tip & How-To about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
How to repair a Shark Steam Mop Model S3101CP (Canada) (not steaming)
My Steam Mop had recently stopped steaming. After reviewing many web sites, most offered that just using a 50/50 solution of CLR/Water or Vinegar/Water would solve the problem. After many repeated tries of both, sadly it did not.
Other online solutions mainly deal with cleaning the core. (see video with a detailed disassembly at the end of this post).
This also did not work!
I did try ripping apart my Model S3101CP (Canada) and testing each section. All the components appeared to work, but no steam. Further investigation found that the nozzle at the end of the steamer was clogged. I tried pushing a coat hanger up the nozzle but it was apparently too large. I took it apart and used a drill bit (by hand) to carefully remove the clog material. Presto! Mop works again. Just wish it wasn't the last thing I tried as I did shortened the heater hose as removing it damaged the ends.
EASY CHECK BEFORE YOU DO ANYTHING ELSE!!
Find a small diameter wire (e.g. over-sized paper clip straightened out) and try pushing it up the nozzle (see photo) to clear any sediment build up. This would have solved my immediate problem.
NOTE: Had allot of trouble uploading photo's with Fixya editor. Please let me know if these are not readable.
A 50/50 solution of CLR/Water or Vinegar/Water would still be a good idea for regular maintenance to extend the life of the mop, if you are not using distilled water (which I stupidly did not). Lesson learned! Use Distilled Water ONLY! It is allot cheaper than replacing your mop and would save you time in repairs.
As promised, here is the video with detailed tear down of your mop (similar model) should the above not work. (not my video).
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
My shark stem mop will heat up, but it won't emit any steam
Did you use a pipe cleaner in the jets, (be careful if steam is hot)
keep doing until it emits steam. Good Luck
Sep 23, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
red devil steam mop no steam coming out
Add CLR to water tank. Let it sit for an hr to overnight unplugged. Plug back in, turn on steam to medium setting and wait about 20 minutes. Mine started to steam and I let it steam for 5 min or so. Empty out CLR, add only "DISTILLED WATER" and clean away. Good luck.
Oct 24, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
k
shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
97 people viewed this tip
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Chris Hall
Chris Hall
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
