Tip & How-To about Tablets & eReaders
Enter God mode on your pc
Windows hidden "god mode" folder Windows offers a centralised Control Panel for all of the OS settings, which makes it easy for users to tweak everything from desktop background to setting up a VPN. To enter this mode, create a new folder on your desktop give it any name you like. Then edit name and type this exactly, copy and paste be best, Just copy every thing inside the brackets, ( GodMode.{ED7BA470-8E54-465E-825C-99712043E01C} ) The folder icon will change to a Control Panel-style icon, and you will be able to jump in and change all kinds of settings. Note: Don't try this on Windows Vista 64-bit as it's known to cause a reboot loop.
Tablets & eReaders Logo
how do i get my axs trio tablet out of demo mode and user terminated?
This is how to remove the demo mode from the Trio AXS tablets:
1. Start tablet. When demo mode starts, click the menu icon and find the CALCULATOR app.
2. In CALCULATOR, type the following "!(364)!" (no quotes). This will put you in admin mode immediately. Click CONTINUE.
3. Enter the password: "Adm!nTr10!" (no quotes, mind the case). Now you have a list of options.
4. Un-check all the BLOCKED APPS.
5. Un-check all the items under DEVICE MANAGEMENT.
6. Exit and reboot.
you're done.
May 24, 2015 | Tablets & eReaders
I forgot password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Jul 29, 2012 | PANDIGITAL 7270FW Tablet
I have a problem with my literati ereader its functioning well until I upgraded it last week now it wont recognize my sd card..I tried others it just wont recognize it. then I tried putting some of my books on the main memory just found out that it is also full. Help please
Solution: Use the Literati USB connection and the following steps
1. Plug the eReader into a charger
2. Download v2.0 of the Literati or Lookbook firmware from - http://download.kobobooks.com/firmwares/merchsource/2-0/KoboRoot.tgz , and save the file somewhere you will remember
  • NOTE: Some browsers will download the file and rename it to KoboRoot.tar. The upgrade will not work with the .tar extension. If this happened with your download, please rename the downloaded file to KoboRoot.tgz
3. Keeping the charger connected, connect the Literati or Lookbook to your computer through the provided USB cable
4. The eReader will appear on your computer as a mass storage device
ON A MAC:
1. Open mass storage device in Finder
2 . Click GO from the top menu
3. Click Go to folder
4. Type in .kobo (include the period).
5. .kobo folder will open
6. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
7. Once the file has transferred, safely eject the eReader
8. Turn off the eReader
9. Turn on the eReader
10. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
11. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
ON A PC:
1. Open mass storage device in Windows Explorer
2. Ensure hidden folders are visible (different for different Windows versions)
XP: Go to My Computer > Tools menu > Folder Options > View Tab > Advanced Settings > Hidden Files and Folders > Show hidden files and folders. Press OK all the way out.
Vista and Windows 7: Start > Control Panel > Folder Options > View Tab > Click Show Hidden files and folders > OK
3. Open .kobo folder in the mass storage window
4. Transfer the KoboRoot.tgz file you downloaded to the .kobo folder
5. Once file has transferred, safely eject the eReader
6. Turn the eReader off
7. Turn the eReader on
8. The eReader will take up to 10 minutes to start up, please be patient and do not reset or power off the eReader in any way.
9. Once the eReader restarts, it will have the latest version (v2.0) installed. You can verify this by pressing the menu button, selecting Settings and looking at the Version number.
Sep 04, 2011 | Sharper Image Literati Reader 16375680042...
forgot password -samsung q1 ultra
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Jan 01, 2009 | Samsung Q1 Ultra Tablet PC
Window will not reboot after
try leave the password blank.
you know? When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So try to logon as adminstrator ,here is the guide:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
if that doesn't work,then just learn from others how to reset windows password with Windows Password Recovery Tool.
Nov 02, 2008 | Gateway M275 Tablet PC
172 people viewed this tip
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
