Tip & How-To about Garden
How to start a flooded 2cycle engine or chain saw
EXTREME Caution should be used. A FIRE can result if this is done improperly !
Perform this outside, and have a fire extinguisher present.
1) Remove spark plug, ground the plug wire if possible
2) Make sure ignition is in the OFF position
3) NO choke
4) Wide open throttle
5) Shop rag over spark plug hole
6) Pull until no liquid comes out of plug hole
7) Re-install spark plug, turn ignition switch to ON
8) Continue to pull recoil with throttle open, NO choke
9) Engine will start slowly with huge amounts of smoke, run until the smoking stops.
Garden Logo
how do you fix liquid locked in a homelite mp88 chop saw
3) NO choke
Feb 15, 2017 | Homelite Garden
Name and explain at least 6 guidelines for placing of fire extinguishers.
Google is your friend in such cases. Read all the pages and make your own findings.
  • Emergency Standards ' Portable Fire Extinguishers ... https://www.osha.gov/SLTC/etools/evacuation/portable_placement.html Portable Fire Extinguishers Extinguisher Placement and Spacing. ... The following guidelines will help you identify the number and types of portable fire ...
  • A Health and Safety Guideline for Your Workplace Fire ... iapa.ca/pdf/FreeDownloads8_fireext.pdf · PDF file Fire Extinguishers © Industrial Accident Prevention Association, 2006. All rights reserved. 1 A Health and Safety Guideline for Your Workplace
  • Placement of Fire Extinguishers in the Workplace safeandcompliant.net/safe-kb/article.php?id=30 Placement of Fire Extinguishers in the Workplace. KB Home ... The following guidelines will help you identify the number ... Fire Extinguisher Size and Placement ...
  • Portable fire extinguishers. - 1910.157 - osha.gov https://osha.gov/pls/oshaweb/owadisp.show_document?p_id=9811&p... 1910.157(a)Scope and application. The requirements of this section apply to the placement, use, maintenance, and testing of portable fire extinguishers provided for ...
  • Guidelines to the Strategic Placement of Fire ... driftwoodontheocean.com/2016/04/11/guidelines-to-the-strategic... Fire Extinguisher Safety and Other Essential ... of placing the fire extinguishers in the ... to place your fire extinguisher, here are a few guidelines to ...
  • Geeks On Home: OSHA Fire Extinguisher Guidelines www.geeksonhome.com/...7717356_osha-fire-extinguisher-guidelines.html OSHA Fire Extinguisher Guidelines. ... The Occupational Safety and Health Administration maintains rules governing how fire extinguishers are used, ...
  • Fire Extinguisher Requirements and References in the ... amerex-fire.com/wp-content/uploads/2013/02/Fire-Extinguisher... · PDF file Fire Extinguisher Requirements ... there are additional requirements for placement, ... servicing and training with portable fire extinguishers beyond the ...
  • Fire Detection and Extinguishing Equipment Regulations laws-lois.justice.gc.ca/eng/regulations/C.R.C.,_c._1422 ... Fire Detection and Extinguishing Equipment Regulations ... Special Requirements; 7 ... Portable Fire Extinguishers; 90 ...
  • http://www.bing.com/search?q=guidelines+for+placement+of+fire+extinguishers&qs=n&form=QBRE&pq=guidelines+for+placement+of+fire+extinguishers&sc=0-46&sp=-1&sk=&cvid=405F1FDF23E64C4A8BD1FC6B5358AE64
    Jul 10, 2016 | Cars & Trucks
    how is fire extinguisher used
    Pull the safety catch, aim at the bottom of the fire (not the top of the flame), and compress the trigger.
    Jan 31, 2015 | Cars & Trucks
    what are the different types of fire extinguishers?
    there are 3 types:
    water
    carbon dioxide
    dry chemical
    to learn more about them go here: http://www.ehs.okstate.edu/modules/exting/Types.htm
    May 07, 2013 | Home
    112 people viewed this tip
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
