Tip & How-To about Epson Office Equipment & Supplies
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wi-Fi not connecting on Toshiba Satellite A15-S157 PC Notebook
you tried giving it a static IP address rather than using automatic settings (i.e. DHCP). Sure enough, this cured the problem, connected fine. I looked in the dhcp server logs and while it was not complaining that the IP address pool was all used, it did seem that all the IP addresses available were being used. I increased the number of IP addresses available to be allocated by the dhcp server and problem solved. The big mystery to me is why Windows XP would report this as a problem with a weak signal? Isn't the access to the dhcp server and the allocation of the IP address at a layer above the wireless connection? Anyway, it's useful to be warned that the wireless diagnostics are misleading.
Nov 05, 2008 | Toshiba Satellite A15-S157 Notebook
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
Home > Wizard
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
129 people viewed this tip
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
