Tip & How-To about Miscellaneous
1994 Chevrolet G20 power window
If you experience an inoperative passenger power window after replacing the master switch (driver's side) with a Dorman 901017, here is a solution that worked for me:
1) Plug in the connector and trim the guide pin, (the longest pin), to just above flush using a good pair of diagonal cutters.
2) Use electrical tape to cover the exposed portions of the electrical components around the bottom of the switch and the guide pin.
The reason for doing this is that the door cavity is too shallow which causes the guide pin to press against the inside of the switch. The stress from the guide pin causes the internal contacts to become displaced. The reason for taping around the exposed conductive portions of the switch are to prevent possible grounding. The reason for taping the trimmed guide pin is to reduce unwanted vibration and noise.
Miscellaneous Logo
Which Relay/Fuse controls the power windows?
Did you check for battery voltage at the switch , with a volt meter before you replaced the main driver door switch ? Maybe you'll want to take this to pro ,instead of just replacing parts !
Symptom Chart Condition Possible Sources Action
  • No communication with the smart junction box (SJB)
  • Circuitry
  • SJB
  • REFER to Section 419-10 .
  • A single power window is inoperative - driver front power window is inoperative/does not operate correctly
  • Power window motor regulator and motor
  • Circuitry
  • Window control switch
  • Smart junction box (SJB)
  • Go To Pinpoint Test A .
  • A single power window is inoperative - passenger front, left rear or right rear
  • Circuitry
  • Go To Pinpoint Test B .
  • All power windows are inoperative
  • Smart junction box (SJB) fuse 30 (10A)
  • SJB circuit breaker 10 (30A)
  • Circuitry
  • Delayed accessory relay
  • Battery saver relay
  • Driver window control switch
  • SJB
  • Go To
PINPOINT TEST C: ALL POWER WINDOWS ARE INOPERATIVE Test Step Result / Action to Take C1 CHECK FOR CORRECT OPERATION OF THE INTERIOR LIGHTS
  • Turn on the interior lights.
  • Do the interior lights operate normally?
Yes
GO to C2 .
No
To continue diagnosis, REFER to Section 417-02 . C2 CHECK CIRCUIT 400 (LB/BK) FOR VOLTAGE TO THE DRIVER WINDOW CONTROL SWITCH
  • Disconnect: Driver Window Control Switch C504b.
  • Key in ON position.
  • Measure the voltage between the driver window control switch C504b pin 4, circuit 400 (LB/BK), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to C4 .
No
GO to C3 . C3 CHECK CIRCUIT 400 (LB/BK) FOR AN OPEN OR SHORT TO GROUND
  • Key in OFF position.
  • Disconnect: SJB C2280c.
  • Measure the resistance between the driver window control switch C504b pin 4, circuit 400 (LB/BK), harness side and the SJB C2280c pin 17, circuit 400 (LB/BK), harness side; and between the driver window control switch C504b pin 4, circuit 400 (LB/BK), harness side and ground.
  • Is the resistance less than 5 ohms between the driver window control switch and the SJB; and greater than 10,000 ohms between the driver window control switch and ground?
Yes
Go To Pinpoint Test H
No
REPAIR the circuit. TEST the system for normal operation.
Mar 24, 2015 | 2004 Mercury Sable
Need help with 1972 dodge dart Door power windows
not sure what you need power goes to the master window switch then to the drivers window motor then the drivers switch that goes to the passenger side in a series so the drivers switch for the passenger side can be bad causing the passenger window to be inop of work up from one and down from the other
Aug 17, 2012 | Cars & Trucks
only front passenger power window won't work. It is not the motor nor the master (drivers side) switch. With only one window inop could it even be a relay or fuse?
Yes it could. Some cars have a fuse for each window. Check your fuse boxes ( diagrams of what fuse powers which circut should be on the back of the fuse box cover) to see if that is the case. Replace fuse if appropriate.
Jun 14, 2011 | 2002 Ford Explorer
rear side windows
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
Principles of Operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
  • All windows are inoperative
  • BJB Fuse:
    • F20.
  • Circuit.
  • Power window relay.
  • Front door power window switch.
  • GO to Pinpoint Test A .
  • Single power window is inoperative
  • Front door power window regulator.
  • Circuit.
  • Driver door power window switch.
  • GO to Pinpoint Test B .
  • Vent power window is inoperative — quarter window glass power latch
  • Circuit.
  • Quarter window glass switch.
  • Quarter window glass power latch.
  • GO to Pinpoint Test C .
  • The one touch down feature is inoperative
  • Master window regulator and door lock switch.
  • INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
  • The back window will not defrost
  • CJB Fuses:
    • F30 (10A).
    • F32 (20A).
    • F34 (20A).
  • BJB Fuse:
    • F27 (45A)
  • Circuit.
  • Heated back window switch.
  • SEC/timer module.
  • Rear window defrost relay.
  • GO to Pinpoint Test D .
  • The back window defrost will not shut off automatically
  • SEC/timer module.
  • Circuit.
  • GO to Pinpoint Test E .
Jan 28, 2009 | 1999 Mercury Villager
2 dr honda accord power window problem
I wouls suspect you have either a inoperative window regulator (the frame work for the power glass) or a bad power window motor. More often then not the are sold as a single assembly and are not very hard to replace on this vehice.
Jun 27, 2008 | 1999 Honda Accord
64 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
Philippe Dekyvere
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
