Tip & How-To about Samsung ML 1710 Laser Printer
Install printer driver for Samsung ML-1710(P) in Windows 10.
When trying to download a printer driver for your Samsung ML-1710 or ML-1710P from samsung webpage they only present you the bloated universal printer driver. But you can download the GDI-driver if you click "See more". Unfortunately this driver will not install in Windows 10, it works fine in Windows 7.
Scroll down to "Downloads", click "See more" and download the "Print driver,GDI 3.01 for Vista/2008" driver from the following link:
ML 1710P
If you attempt to install it you will run into an error 0x800f024b about invalid hash value or similar.
Before installing the driver we need to disable the Windows 10 driver signing check. This will restart your computer midway so enter the steps below on a piece of paper before starting the procedure!
  1. Click the "Start" button.
  2. Type "startup".
  3. Select "Change advanced startup settings".
  4. Select "Restart now" under the "Advanced startup" area.
  5. Select "Troubleshoot".
  6. Select "Advanced Options".
  7. Select "Startup Options".
  8. Select "Restart". Your computer restarts.
  9. A menu will appear where you can press "7" on your keyboard to choose "Disable driver signing enforcement".
The above instructions comes from:
Enable Disable Device Driver Signing in Windows 10
And you should now be able to install the drivers you downloaded previously!
Samsung ML 1710 Laser Printer Logo
Hello I cant instal my Samsung ML 2010 Laser printer on my laptop using Windows 7 64 bit. The problem is in instalation - argument invalid or somethink like this error Please help me i need this fast
Try downloading the latest drivers directly form Samsung. The link is below, at the top of the page click Driver, and on the list (right hand side) click the icon for Universal Print Driver. I would save the file to an easy to get to place (i.e. the desktop). After you download it, run it.
http://www.samsung.com/us/support/downloads/ML-2010
I hope this helps and solves your issue.
Jul 22, 2011 | Samsung ML 2010 Laser Printer
driver for w7
Copy the link below and paste it onto the address bar. Download and install it after.
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=2305398&CDCttType=DR&ModelType=C&ModelName=ML-1210&VPath=DR/201011/20101115101918937/Samsung_Universal_Print_Driver.exe
If you're having difficulties, go to http://www.samsung.com/us/support/downloads/ML-1210 and click on the universal printer driver.
Mar 03, 2011 | Samsung ML 1210 Laser Printer
I require printer driver for Samsung ML 1610 as I do not own the printer driver
go to Samsung official website and download the "universal printer driver". It takes several hours but well worth it and is a great improvement over their old driver.
Mar 08, 2010 | Samsung ML 1610 Laser Printer
874 people viewed this tip
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
