Tip & How-To about HP Pavilion Computers & Internet
Why HP-p 077tx Laptop Working Slow and Fan RPM Is Maximum?
Is your HP-p 077tx laptop running slowly and making a lot of noise? If so, then it could be overheating.The electrical components in the PC make heat, and fans in the system help move the air to keep the modules from getting too warm. Extra heat will be the reason for fans to run continually, damage modules, and slow the CPU's speed.All of these failures with higher heat and power will cause the program to function slower than normal. If the Fan RPM is extreme all the time, it can be the first hint that your laptop isn't working efficiently. To run your system as cool and effectively as possible, either call at the HP technical support phone number or follow up one or more of the corrective actions given below.
Update your HP laptop BIOS
While computers are released, HP also distributes updated BIOS to manage CPU power loads, fans, and other modules. Before updating the BIOS, make sure that what BIOS version is currently installed on your system. If it's outdated, then update it to the new version available on the HP's official website. For complete information to find new BIOS version and know the instructions for updating your laptop BIOS, consult with the HP technicians to get the necessary help.
Improve the laptop efficiency to reduce heat
If you have various applications running on your system, it functions harder and creates more heat.Decrease the heat amount by improving the laptop efficiency. Here's how to do:
    ·Stop your application from initiating while the system is started.
    ·Close the additional programs if you're not using them.
    ·Disconnect the Internet if you're not surfing the web.
    ·If your laptop gets too hot while playing games, then try to play the game at a lower resolution and with reduced graphics settings.
    Identify corrupt processes using Windows Task Manager
    The regular CPU load can be the reason of heat buildup in the computing device, forcing the fan to work regularly to keep the system at functioning temperatures. Sometimes, corrupt program or malware can cause the heat buildup. A corrupt program can consume CPU time wherever between 1% and 100%. Follow the steps to find corrupt processes that might be making CPU slower.
      1.Save your work and end up all open applications.
      2.Press Ctrl-Alt-Delete keys all at once. Click the 'Task Manager' to reveal the Windows Task Manager window.
      3.Choose the 'Processes' tab, and to specify the processes by CPU load, and then click the CPU column header.
      4.Navigate the list of suspect processes.
      To identify more details about a process, browse the Internet to find the procedure name that shows in the Windows Task Manager. You can also avail tech support for HP laptop and get the suggestions for solving the issues.
      Keep your Laptop air vents clear and clean
      When heat builds up due to the regular use of the system, the fan spins faster to eliminate the excess warm and thus make the noise. HP laptop has vents in the bottom and sides to eradicate heat, letting air flow via the case. If the vents become blocked, the fan can't cool the components correctly. So, clean the dust if you find it out and inside the vents. While using your laptop, put it on a hard, smooth surface to keep the vent areas unblocked.
      Choose power save settings
      Try to choose the power save settings to shut your laptop off while it's not in use. Many operating systems let you change the power settings to turn off the screen while you're not regularly using your system. If you often leave your laptop in between your work, changing the power settings to power off your monitor while it's not being used can let your laptop functioning at a cooler temperature.
Computers & Internet Logo
Hp g62 overheating
A good clean of the intake and exhaust vents is a good place to start.
Next up is to ensure that your notebook is raised off of the work surface (table) to allow greater airflow through the notebook to cool it's components.
Use a pencil or eraser, some-thing that will lift the notebook and not restrict airflow.
Another solution is to purchase a notebook cooler, some units have a built-in fan which will help a lot.
Take care!
damnor01
Sep 12, 2012 | HEWLETT-PACKARD G62-347NR Laptop
My HP laptop charger makes beep noise and laptop doesnt get charged... wats gone wrong..
I believe that a component has been damaged and the beep is a warning that it should be sent in for repairs.
This could have been caused by heat (since chargers produce lots of heat) and/or by a fall or something similar.
Jun 04, 2011 | Computers & Internet
overheating
check if the fan is working if it is remove heatsink clean heat paste and replace with new paste dont put to much only small squirt in the centre of the cpu as the heatsink will spread it once connected again....
Apr 07, 2009 | Fujitsu Siemens LifeBook P7120 Notebook
Fan makes a lot of noise, then computer suddenly shuts down
Seems to be overheating. When you say the fan makes a lot of noise, do you mean an unusual noise or just that it is on high?
Feb 10, 2009 | Acer Aspire 5002WLMi Notebook
hp compaq dc5000sff cpu fan sounds like a jet taking off
Not sure how long you have had the Desktop. However it will be one of two things. If it used to run quitely and now is making lots of noise then immediately take it to be replaced. Fans on power supplies cannot be fixed. If it should stop completely then the heat that builds up in your desktop could damage your components. Second, if it is fairly new and has always sounded that way then you are ok. Yes, there are some fans that are very loud, again you can have it replaced. They sell "quite fans" now that make no noise at all. But first and foremost if you start having problems like unusual reboots, lock ups, etc then your computer is getting overheated and the power supply which houses the fan needs to be replaced. Hope this helps.
Dec 24, 2008 | Computers & Internet
186 people viewed this tip
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
