Tip & How-To about Miscellaneous
Why the removal of impurities in the oil? Most of the impurities for oil quality and storage safety disadvantage. Such as water not only affects the transparency of oil and grease will lead to hydrolysis rancidity; insoluble impurities and acidic substances are contributing factor to grease deterioration; FFA affect the flavor, promote the deterioration; phospholipids make Grease muddy, but when heated to produce a black precipitate, blistering, hair waiting; Various pigments directly affect oil color, and some will promote fat rancidity; gum, sulfur, phosphorus compounds and soap, heavy metalsalts such as the existence of subsequent processes such as acid stripping off difficulties hydrogenation catalyst poisoning; ,
Miscellaneous Logo
The car uphill obvious weakness, engine power performance Descent
This is probably due to not cause prolonged oil changes, oil filter, air filter causing incomplete combustion of fuel, increased engine deposits and other issues.
Recommended oil, oil filters, each with about 5,000 km to be replaced once, air filter and oil filter every 10,000 km driving needs to be replaced, otherwise the air, fuel and oil impurities cause parts wear and clogging the oil, thus affecting the normal operation of the engine.
Use obd2 for automotive diagnostics , you can improve vehicle safety performance and driving more safer.
Dec 11, 2013 | Ford Cars & Trucks
cause of oil pump failurein vw sharan 18t
Bad or contaminated oil - remove the oil pan and check for impurities and water - or low oil level due to a loss thru a leak or the oil hasn't been replaced at the required intervals.
Oct 03, 2013 | Cars & Trucks
i have olympus camedia 4.0 mega pixel. old camera. need to know how to change the camera photo storage from 18 photos to at least 64 photos storage
Hi, jamesepatton, and welcome to FixYa.
I am going to assume that you are referring to the camera's internal storage, as opposed to the camera's removable storage card.
Obviously, to increase the storage on a removable card, one need only purchase another, higher capacity storage card.
To change the camera's internal storage capacity, one needs to reduce the resolution of the pictures one takes.
Example- your Olympus is capable of taking a 4.0 mega pixel sized picture. This size picture can generate a fairly large data file (after all, pictures- like Word documents- are only data files!) While this is what is normally programmed into the camera at the factory, you are not 'married' to this size. In the "Setting" menu of the camera, there will be an option to change the mega pixel (mp) setting. Try lowering it to the next lower setting (say, 3.0 mp) and shoot until the camera tells you it's full. You may have to try several different mp setting, but eventually you'll land on the right one. It's going to depend a lot on what is in your pictures as well, as different scenes and content can affect file size.
A quick note here: Lowering the mp setting will affect the quality (and/or resolution) of the photo. I have found that for a great majority of the photos that I personally take, a 2.0 mp setting is just fine. I am by no means shooting magazine covers or entering my pictures in contests, I shoot 'em, print 'em and save 'em. Just your basic home pictures.
If resolution/quality is important, I would highly recommend that you save ALL pictures to a removable memory card and leave the camera set on 4.0 mp.
Good luck, and let us know how you go!
Aug 10, 2011 | Olympus Cameras
118 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
