Tip & How-To about Miscellaneous
Meaco Dd8l dehumidifier fault light
My unit developed a fault just after the warranty expired. After less then a minute of turning it on the double fan light would flash, the fault light would come on and the unit would shut down.
After some research it would appear to be a common problem with this unit.
after stripping down the machine and inspecting it I noticed the dissident wheel was not turning. I removed the small electric motor, opened it up and re greased all the internal plastic cogs and re assembled, easy enough. Before re fitting motor I manually turned the dissident wheel and noticed it catching on something, preventing it from turning. On removal of the wheel I could clearly see the plastic case behind had melted and distorted. In the area directly behind the heater element. The dissident wheel has metal 'spokes' that literally brush past the plastic case behind.
i admit the unit has been turned off a couple of times before the unit has shut down properly and my guess is that the metal 'spokes' have stopped over the heater element and still hot element has heated through the spoke and melted the plastic behind, causing the distortion. Or this may be a design flaw, but was easily rectified by smoothing back down the plastic. On re assembly the unit worked like new.
Miscellaneous Logo
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks Rob.
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
fan @ compressor wont run,one light is flashing
flashing light is showing an error code. if the unit is under 5 years old it will be covered under warranty.. if you want you can try and reset the power by turning it off at the isolator next to your outdoor unit, leave it a couple of minutes and switch it back on. this will reset the fault code, if the flashing light comes back there is a definite problem, if it runs the fault may have been caused by a power surge or something
Dec 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
horizontal flashing color stripes.1/2 second intervals on pic
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 07, 2017 | LG 42PG20 42 in. Plasma HDTV
673 people viewed this tip
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
