Tip & How-To about Magellan eXplorist GPS
FIX Your Corroded Battery Contacts in the Magellan Explorist 510 610 and 710 GPS
Do not despair. Many users find that the batteries in their Magellan Explorist 510 610 and 710 GPS devices leak. The corrosion weakens the battery contacts and causes power not to be supplied to the GPS. Unfortunately Magellan does not sell or offer these critical parts. The Gelb Organization (http://www.gelb.com) has had the parts created so that the user can order a DIY kit to replace the bad parts. The parts are accompanied by a complete instruction manual on how to do the FIX IT.
Image of New Precision Corrosion-Resistant LASER CUT PLATED SPRING STEEL REPLACEMENTS.
Image of Corroded Battery Contacts
JG
GPS Logo
New batteries installed and will not switch on?
Jim, Look for battery corrosion on the contacts. Also install some Lithium batteries and see if the unit will fire up. If the unit has battery contact problems, they are available on the www.gelb.com website or eBay. JG
Sep 19, 2015 | Magellan eXplorist 100 GPS Receiver
my gps magellan explorist 510 cannot open up after ppower on.
From your question it appears that the unit has some corrupt internal memory files. Please return the unit to Magellan. JG
Jul 09, 2014 | Magellan eXplorist 510 GPS Receiver
how can I set up to user grid a Magellan eXplorist GC?
Hello
I've the user manual for Magellan eXplorist. But I can't send it to you by this window, as it does not allow me to upload PDF files by it. If you send your Email address to me by Fixya Comment box, I'll send a copy of it to you by return mail. OK.
Oct 31, 2011 | Magellan eXplorist GC GPS
explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
227 people viewed this tip
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
