Tip & How-To about Miscellaneous
How is palm kernel oil extracted?
Facts of palm kernel oil
As we all know, the palm fruit can be used to make healthy red palm oil, but do you know the palm kernel can also be extracted to obtain palm kernel oil? After the palm fruit oil gained and fiber and palm nuts left as by-products, in most time, the fiber is used to make a fire, the nuts left behind, however, can be further processed to obtain palm kernel oil.
Made from the seeds of palm plant, palm kernel oil is more saturated than palm oil and comparable to coconut oil, it is semi-solid at room temperature and is mainly used for cooking since its cheap price as well as its stable properties when cooking with high temperature and can be stored for a longer time than other oils. Palm kernel oil is also able to be used for many other purposes, e.g. pomade (body cream), medicine, frying fish, making stew, making soap, etc.
How many ways to extract palm kernel oil?
There are two common methods of extracting palm kernel oil, one is full press extraction where mechanical screw oil press machines are used to extract oil out by squeezing under high pressure, this oil extracting method is mainly used by small and big capacity oil mill plants. The other method is solvent extraction with hexane, where a solvent is mixed with the material to separate the oil, this extracting method, however, is generally used by larger capacity oil processing mills. You can choose the one that suits you best according to your daily capacity.
Solvent extraction method is recommended for much bigger capacity oil mils, for small capacity oil extraction mills, the former method will be better. Solvent extraction processes can be divided into three main unit operations: kernel pre-treatment, oil extraction, and solvent recovery from the oil and meal.
palm oil extraction process
palm oil press machine and palm oil refining machine
Palm Oil Processing Plant Palm Oil Mill Process Machinerymanufacturerssalep... Cooking oil machine Manufacturer of cooking oil machine and biodiesel...
Miscellaneous Logo
Do you know of a healthy fruit popsicle treat to cool down in the hot months?
Here is an easy, healthy recipe
http://allrecipes.com/Recipe/Fresh-Fruit-and-Yogurt-Ice-Pops/Detail.aspx
Jan 10, 2013 | Cooking
Is freeze-dried food healthy?
Freeze dried fruit can be a nutritional boon to anyone who wants to maintain a healthy diet through all four seasons, because some fruits are only available seasonal. Some freeze dried fruits will not maintain their full amount of vitamin C through the drying process, but when a fruit is fresh, you can be certain that it contains the maximum possible nutritional value. In addition, fresh fruit contains a large quantity of water, which helps you feel full and satiated while it helps your system stay hydrated and efficient. Although some freeze dried fruit is slightly lower in vitamin C, research suggests that the vitamin and nutrient content of freeze dried fruit remains roughly similar to that of fresh fruit. There are advantages to both fresh and freeze dried fruit, so whichever fits more conveniently into your lifestyle and dietary habits is the right choice for you. Whenever fresh fruit isn't practical or available, you can chow down on a piece of freeze dried fruit and revel in the knowledge that you are doing right by your body.
Jul 10, 2012 | Camping, Backpacking & Hiking
what are the ingredients of long last soft shine lipstick (ALL HEART)?
ricinus communis (castor) seed oil, euphorbia cerifera (candelilla) wax/candelilla cera/cire decandelilla, isopropyl palmitate, phenyl rimethicone, dipenaerythrityl hexahydroxystearate/hexastearate/hexasosinate, octyldodecanol, diisostearyl adipate, microcrystalline wax/cera microcristallina/cire microcristalline, ceresin, ozokerite, triticum vulgare (wheat bran) extract, olea europaea(olive) fruit extract, aloe barbadensis leaf extract, lecithin, linoleic acid, tocopheryl linoleate/oleate, octyldodecyl, myristate, cholesterol, glyceryl rosinate, ethylene/va copolymer, silica, bht [+/- mica, titanium dioxide (ci 77891), iron oxides (ci 77491) ci 77492, ci 77499), yellow 5 lake (ci 19140), red 7 lake (ci 15850), red 28 lake (ci 45410), yellow 6 lake (ci 15985), blue 1 lake (ci 42090), red 33 lake (ci 17200), carmine (ci75470), red 6 (ci 15850), bismuth oxychloride (ci 77163), red 30 lake (ci 73360, red 22 lake (ci 45380)] Personally, this does not make much sense, but I hope it helps!
Aug 27, 2011 | Clinique Long Last Soft Shine Lipstick All...
136 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
