Tip & How-To about HP Officejet 5610 All-In-One InkJet Printer
Refilling 5610 cartridges saves Big Bucks!
For those who have not yet tried to refill their own cartridges, you are really missing the boat on big savings.
Remember, printer companies make very little money from their hardware sale... they make TONES of money from their repeat cartridge sales.
That is why they want the empty ones back... they say "to protect the environment and recycle". I don't doubt that but they are really after recycling the perfectly good cartridge and your money while protecting the environment falls at a somewhat lower priority. You will note that the cartridges are not all that large (ink volume) wonder why that is :-) ???
Although the cartridge may be used up, it is good for many, many, many more reloads if properly maintained. I have successfully refilled my black cartridge eight times and the color five times and both are still going strong and have perfect printing quality!
You can purchase ink refill kits from eBay... try a search for "inkjet refill kit for HP". You will probably find several kits available but I got mine from the eBay store owned by Distribution-Online. I have no connection with this reseller other than I use their products and the prices seemed fair. They include detailed instructions so getting started is easy (you need an electric drill, a small drill bit and some scotch tape). Last check, the black ink was about $9 and the color set was $16.
Hints for the HP5610:
1. Refilling the cartridges will not get rid of the low ink message. If you see this, simply press the "ok" button to erase it.
2. You will need to watch your print quality to tell when they need to be refilled. (I.E. faded blacks or wrong colors)
3. Refill your cartridges immediately if you see one is empty. Not doing so may cause it to dry out internally which is a cartridge killer.
4. When filling the cartridges, fill them slowely so the ink is absorbed by the internal "sponges". Overfilling is possible (go slow) but does no damage. You will soon get a feel as to what colors are used up the most. Black goes quickly followed by Cyan with Yellow and Magenta after that.
5. After you fill, clean the underside of the cartridge ( print head that contacts the paper) with high quality alcohol each time you fill, blow it dry.
6. After you fill, clean the connection points on the back of the cartridge (copper contacts) with high quality alcohol each time you fill, blow dry.
Each time I refill, I smile and say to HP (and all the other print cartridge manuactures), I am just doing it... "to protect the environment and recycle"
Good luck and give it a try! -Dan
HP Officejet 5610 All-In-One InkJet Printer Logo
can i refill conair butane cartridge
There are two videos on YouTube on the subject. Before you start, remember neither the Fire Marshal nor your insurance company will be happy with you when you burn the house down.
How To Refill Thermacell Butane Cartridges Cheap Save Money
How to refill thermacell butane cartridge the easy way Save money
Feb 27, 2015 | Conair Instant Heat Curling Iron, Model...
i just installed two refilled lexmark cartridges color and black yet printer is reading black cartridge missing and color cartridge missing. I am unable to print
Refilled cartridges become unreliable and can damage your printer - you will need to try an original Lexmark cartridge before considering replacing your printer.
Sep 05, 2011 | Lexmark Z2300 InkJet Printer
Lexmark x7350 all-in-one printer says "missing cartridge" even though the color cartridge is not missing. i have tried wiping off the strip on the cartridge and turn off..waiting.. and turning the printer back on and it still says the cartridge is missing. The cartridge is a new correct cartridge
Exchange the cartridge for another new Lexmark cartridge. I think Lexmark printers have gotten so finicky about kicking out refills that they sometimes reject original cartridges. I own a cartridge refilling store and I've had a couple original Lexmark cartridges returned because the printers didn't recognize them.
Nov 24, 2009 | Lexmark X7350 All-In-One InkJet Printer
replacing empty cartridges
Make sure that the cartridges you installed are compatible for your printer.
Refilling the ink could actually damage the head that is why it is not advisable to refill, this will cost you more money for printer replacement.
Reseating the ink cartridges and rebooting the whole system could do the trick.
But if not, check if ink cartridges are really defective or has dried out so you can fix a return for those lemon.
This way we can identify if you really need to replace the printer instead of jumping into conclusions right away.
Thanks.
Jan 06, 2009 | Lexmark X6100 Flatbed Scanner
3,079 people viewed this tip
Clive
Clive
Thomas F. Schneider
