Tip & How-To about Miscellaneous
Getting an answer
If you have a problem that needs solving, please add as much information needed so you will get an accurate answer. There so many questions that are partial or missing information on Fixya. Please be detailed with the product and symptoms experienced. We can't help unless the information is provided. Good luck!
Miscellaneous Logo
What should I do if the answer to my question doesn't solve a problem?
take it in for a proper diagnosis and quote
you have to remember that answers are only given on information you provide so it that is not accurate then the answers will be general only
Feb 07, 2018 | The Office Equipment & Supplies
I just bougt a tower to hook up to a dell monitor I already had and once I hooked it up it keeps saying no bootable device
Hi tjgcs
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System and my answer seems to be of some relevance to you, please consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question. Please include information about the type, model and specification of your computer and its Operating System. Doing so helps us makes faster, more accurate and more assured Remote Diagnostics leading to better quality and more useful Advice, Answers, Guidelines , How-Tos and Solutions.
You also don't say where you bought the computer and how old it is.
A more easily solved potential cause of the same symptoms could be poor contact between the physical hard drive and the motherboard (possible result of a drop or a knock dislodging cable connectors). If so this is easily fixed by opening the computer and checking both the data cable and power cable connected to the Hard Drive.
Alternatively, it might be that the Hard drive is not configured properly in BIOS. Check the IDE/SATA Settings are correct for you format of hard drive. Check that the Boot sequence gives the hard drive with the operating system on it the correct Boot priority.
Make sure there are no CDs, Floppy Disks, Memory cards or USB Memory Sticks in the optical or Floppy Disk drives, Card Reader slots or USB Ports that could be interrupting the Boot process.
If none of these apply then the Hard Drive might be faulty and need replacing.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Dell Computers & Internet
installed dvd express usbav701rev2.cap wiz says unable detect capture device driver downloaded from ads does not install help needed
Hi baldev13249
Since you have not revealed you Operating System, I cannot be sure but it seems your capture card may be RevB (Revision B) and if RevB is the same as Rev2, then only XP Drivers seem to exist for it. If your Operating System is not XP, maybe this is the problem.
In any event, look here for further guidance on the exact model:
http://www.adstechnologies.com/index.php?main_page=page&id=13&language=fr
I hope this helps.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
Sep 07, 2011 | A D S ADS DVD Xpress (DHUSBAV701)
take facebook off of my homepage
Hi
Launch Web Browser > Tools > Internet Options > Highlight all of whatever appears In the Home Page Box > Copy & Paste (an unusually Useful Home Page) this:
http://www.google.com/ig/emachines?hl=en
Apply > OK > Restart Computer > Test knew Home Page > Configure Home page with preferred gadgets and to preferred Preferences.
I hope this helps.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most insightful, comprehensive, useful and high quality Responses and Solutions we can.
Sep 05, 2011 | Computers & Internet
92 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
