Tip & How-To about Miscellaneous
Custom Motorcycle Pipes
Product description:
Product name: Custom motorcycle pipes
Brand name: Xinbo
Material: 100% carbon fiber, carbon fibe composite
Surface finish: 3k twill weave or as requested
Technique: winding cross
Service: OEM
Feature: High strength, durable, long life, high temperature resistance
Diameter: 500mm below can be customzied, or as requested
Length: As requested
MOQ: 100 pcs
Packaging: Bubble bag and carton
Delivery Detail: 15~20 days
By UPS, DHL, Fedex, SF Express.
By SEA (please advise the name of the destination Seaport, thanks)
By AIR (please advise the name of the destination Airport, thanks)
Features: Custom motorcycle pipes, the technology is winding cross, so it's more durable. Surface finish, it can be 3k weave, natural, etc. It can be produced according to your request. Diameter, 500mm below can be customized or according to the order. About the length, it can be made as your requirement. And it also can be used for cars. If you have any doubts, you can contact us at all times
Miscellaneous Logo
How do I change disks in my Makita PA - GF 30? Thank you
PA GF30 is the base material of the housing set of the machine not the model number made a google search for " makita saw " on pictures the chance is that you find your model .
Feb 05, 2017 | Makita Saws
How can i repair a crack in my hard case swiss cargo roof rack carrier?
I would use fiberglass (resin, hardener + cloth) on the inside after thoroughly scuffing (and if necessary drilling reinforcing holes) the carrier surface. If after doing that the exterior is not to your liking you could remove any loose material, fill any low areas with auto body filler, sand smooth, and paint. This type of repair will be watertight and likely stronger than the original piece. I have done similar repairs on fiberglass, plastic, carbon fiber, and wood. If the carrier is smooth plastic I would recommend drilling small holes along that crack to allow for a better bond. If it is fiberglass carbon fiber or another composite course scuffing should suffice.
Mar 21, 2016 | Cars & Trucks
What materials are whitewater helmets made out of?
The best and safest whitewater helmets are made out of carbon fiber, Kevlar, and composite polymers. Plastic helmets are not recommended even though plastic was the main material for helmets for decades.
Feb 03, 2013 | Boating
valves rattle during acceleration,does it have tension adjusters on it
Hydraulic lifters on your model, there are cam chain tensioners sometimes those go bad, I would go by a Kawasaki dealer and get a product they brand under the Kawasaki name called carbon clean, you might have a carboned up engine, stuff really works, Yamaha also sells the same product there’s is called ring free.
Apr 13, 2010 | 1996 kawasaki VN 1500 Vulcan Classic
78 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
