Tip & How-To about Miscellaneous
IPhone parts wholesale suppliers answer questions
Many friends will meet iPhone hardware problems, but do not know how to deal with, such as WIFI problems, screen replacements problems, battery problems, etc., now let professional iPhone parts wholesale suppliers answer some of the common questions, Some help and reference:
Q: Home button is not insensitive, how to solve the problem except change?
A: Use alcohol to clean the home key electric shock, no need to change.
Q: Can not be charged in the boot state, can only be turned off to charge, connected to the computer can also be charged. Excluding charger and data lines. what's the problem?
A: Replace the tail plug, or use the tweezers a little cotton, dipped in alcohol to clean up the tail plug, ensure OK, repair a lot of this.
Q: Wireless is easy to bad! I heard there are high-temperature WIFI chip and normal type!
A: Is the same, install the WIFI module, with the air gun temperature of 370 degrees, so there is no damage to the module problem, usually because of Weld, because the WIFI module is not sealed plastic.
Q: After fell, the iPhone signal is not good, that is, in the same room same location, before is full grid, now generally only three cells. But in general outdoors full grid. Except the motherboard, other screen box all changed, the signal also not good, why?
A: The wreck of the heavier machines, there may be a lot of failure, check the battery next to the card deck is not a solid antenna installed, fixed antenna card is small but useful, usually repairer are too lazy to install that card.
Q: On the boot white apple, and sometimes can into the system, and sometimes not. Brush system many times also this case, should be a hardware problem? Light fall! Thank you!
A: The software problem, it is not a good judge, if there are relatively large hardware problems, Brush will be error, 4S is the case, if it is 5, small problems are likely to cause no boot, Brush error.
Q: How to install iPhone screws without leaving any traces?
A: 1, screwdriver to withstand the screw, the screw on the key with the top, not screwed.
2, screwdriver head put on plastic bags, go screw again, leaving no trace.
Q: Lock screen key is bad before, and then to change the inside of a small thing, the lock screen key feeling is change
A: A small black yellow tape insulation gasket on key contacts, it should be repaired when the repairer may not give you a good repair or substitute with something else, the feeling will be bad of course.
Miscellaneous Logo
iphone 4 screen
hi friend,if you have any problem with Phone repair ,please add my whatsapp:+86-18300007189,all the help is free ,and we have high quality IPhone LCD with Lifetime Warranty and we are paypal elite Merchant in China,reply me to know more:)
ETtrends The Leading Integrated Service Provider of Mobile Accessories
Nov 27, 2012 | Apple iPhone4 4G iPhone 4
Cracked screen
on a 3g iphone the glass/digitizer replacement is pretty easy, definitely much less than replacements of ATT or Apple if you can do it yourself, there are iphone repair guides websites that guide you through the repair step by step, but you should have done something like this before.
Mar 19, 2009 | Apple iPhone (16 GB) Smartphone
iphone Frozen in Boot Screen
hello again!
try to restore option first on your iphone.
step 1: Make sure you have an Internet connection and have installed iTunes 7.4 or later from www.apple.com/itunes. .
Step 2: Connect iPhone or iPod touch to your computer.
Step 3: In iTunes, select iPhone or iPod touch in the Source pane and click the Summary tab.
Step 4: Click "Check for Update." iTunes will tell you if there's a newer version of the iPhone or iPod touch software available.
Step 5: Click Update to install the latest version of the software. Or click Restore to restore iPhone or iPod touch to its original settings (this erases all data on iPhone or iPod touch). Follow the onscreen instructions to complete the restore process.
May 08, 2008 | Apple iPhone Smartphone
iphone wifi
You need to select the 'Settings' button on the home screen, then make sure that the 'Ask to Join Networks' option is turned on. Choose your network, and then enter in your password. I've had the same problem before, and it turned out that my phone wouldn't connect without setting the computer to require a password. If this doesn't solve your problem, please let us know.
Feb 20, 2008 | Apple iPhone Smartphone
120 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
