Tip & How-To about Miscellaneous
Yahoo customer care helpline number
Not able to add a folder to your Yahoo mail account according to your preferences? If yes, then you need to dial Yahoo customer support phone number. With the aid of the number, you will get the right aid for adding the folder in your account. The tech expert will guide you the effective method for adding a folder in mail account. On the other hand, a third party tech support providing company is the ultimate option to obtain hassle-free tech support solutions. You can know more about Yahoo tech support solutions by getting in touch with the company's tech professional.
http://www.email-technical-support.net/yahoo-technical-support.html
Now you can easily add an additional layer of safety and security to your Yahoo mail account with two-step verification. With the help of two-step verification you can use both your password and an extra security method to authenticate your individuality whenever you sign in to your yahoo account. In case someone else tries to use or access your account then till they are not able to access your account, even if someone knows or guess your password. With the help of 2 step verification security in yahoo mailno one can be able to get in to your account without using two-step verification.
Yahoo Technical Support Number USA Canada
Miscellaneous Logo
How can I setup my Yahoo Mail a/c in my LG GS500V mobile phone? Please help.
First open your email application from the top level menu. If no other accounts have been setup yet, it will ask you to setup email. Click yes. If you have already configured other account, then open email application and click on the button on top left corner and select add account. E-mail wizard opens. Now,
  1. Click others
  2. Type your full email address under E-mail address
  3. Provide your yahoo password under Password
  4. Click Save
  5. Under Username again provide the same email address as in step 2
  6. Click Save
  7. Select IMAP4 under Mailbox type
  8. Under Incoming server, enter imap.mail.yahoo.com
  9. Under Outgoing server, enter smtp.mail.yahoo.com
  10. When asked for SMTP authentication, leave it on
  11. Again just click Save when it shows you SMTP username and password
  12. Under Account name, enter any name and click Save
  13. When it asks for Update inbox now?, click No
  14. Click Done
  15. Now click your account name
  16. Click the top left button and select Settings
  17. Under Access points, select the access point of your current network
  18. Scroll down further and select Advanced settings
  19. Under both SMTP TLS/SSL and Incoming TLS/SSL, select SSL
  20. Now click Save
That's all... Your email is setup now. To access your email, open your account and from the top left menu options, click Synchronisation. If everything is Okay, it will login to your account, and retrieve any custom folders that you have created in Yahoo Mail. Now, open each and every folder, such as Inbox, select Synchronisation from the top left button menu. It will retrieve your emails from the corresponding folder.
Nov 12, 2010 | Yahoo Mail
Hi There, In the US, getting my yahoo email (using Mail program on a MacBookPro) (yes I have yahoo plus) works like a charm. But here in Canada, most of the time, the password gets rejected... what's give?
To set up access to a free Yahoo! Mail account in Mac OS X Mail:
* Install MacFreePOPs and make sure the freepopsd service is running.
* Select Mail | Preferences... from the menu in Mac OS X Mail.
* Go to the Accounts category.
* Click + at the bottom of the Accounts list.
* Type your name under Full Name:.
* Enter your full Yahoo! Mail address (e.g. "example@yahoo.com") under Email Address:.
* Type your Yahoo! Mail password under Password:.
* Make sure Automatically set up account is not checked.
* Click Continue.
* Make sure POP is selected under Account Type:.
* Enter "Yahoo! Mail" under Account Description:.
* Enter "localhost" (without the quotation marks) under Incoming Mail Server:.
o If you run into problems using "localhost", try "127.0.0.1".
* Type your full Yahoo! Mail address ("example@yahoo.com", for example) under User Name:.
o Mac OS X Mail probably has already entered your user name, and it's enough to append "@yahoo.com" to complete the address.
* Click Continue.
* Click Continue again, ignoring the error. We'll take care of that in a bit.
* Make sure Password is selected under Authentication:.
* Leave Use Secure Sockets Layer (SSL) unchecked.
* Click Continue.
* Select an existing mail server to send mail under Outgoing Mail Server:.
o You cannot send mail through MacFreePOPs. If you have no outgoing mail server through your ISP, you can use a Gmail or AIM Mail account's.
* Click Continue.
* Now click Create.
* Highlight the Yahoo! Mail account in the Accounts list.
* Go to the Advanced tab.
* Enter "2000" (not including the quotation marks) under Port:.
* Close the Accounts window.
* Click Save.
Access Free Yahoo! Mail with Mac OS X Mail Using IMAP Over IzyMail
To add a free Yahoo! Mail account in Mac OS X Mail using IzyMail, which provides access to all mail in all folders seamlessly:
* Make sure your Yahoo! Mail account is registered with IzyMail.
* Click + under the accounts list.
* Make sure IMAP is selected under Account Type:.
* Type "Yahoo! Mail (IzyMail)" under Account Description.
* Enter your name under Full Name:.
* Type your complete Yahoo! Mail address under Email Address:.
* Click Continue.
* Enter "in.izymail.com" (not including the quotation marks) under Incoming Mail Server:.
* Type your full Yahoo! Mail address under User Name:.
o If your Yahoo! Mail address is qwertui@yahoo.com, do type "qwertui@yahoo.com" (omitting the quotation marks).
o Mac OS X Mail probably has already entered the user name for you. If you already find "qwertui" in the User Name: field, just append "@yahoo.com".
* Enter your Yahoo! Mail password under Password:.
* Click Continue.
* Type "out.izymail.com" (without the quotation marks) under Outgoing Mail Server:.
* Make sure Use Authentication is checked.
* Enter your full Yahoo! Mail address under User Name:.
* Type your Yahoo! Mail password under Password: again.
* Click Continue.
* Click Continue again.
* Now click Done.
* Cloe the Accounts window.
* Click Save.
* Open the _Draft folder under Yahoo! Mail (IzyMail) in the folder list.
* Select Mailbox | Use This Mailbox For | Drafts from the menu.
* Open the _Sent folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Sent from the menu.
* Open the _Trash folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Trash from the menu.
* Open the _Bulk folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Junk from the menu.
Done!
Aug 15, 2009 | Yahoo Mail
spam filter not working efficiently
Has anybody known Yahoo spam filter to work as it should. Not really, until Yahoo upgrades this filter there isn't much you can do, however, I have set up alternate accounts with yahoo and I only use them for a specific purpose, no browsing no downloading, just use them to receive important mail. I haven't had spam in these alt. accounts forever. If you need further help call this number:
Customer Care
http://help.yahoo.com/
1-866-562-7219
anaanymous
Oct 04, 2008 | Yahoo Mail
166 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
