Tip & How-To about Android Apps
How to change the value of any Android apps and game
Here I'm going to tell you how you can modify a value of any application or game on Android.
To change the value of any game or app on Android, you just need to following steps:
  • Download GGuardian app on Android - GGuardian APK Download
  • and follow the steps mentioned in the link given below.
That's it. Now enjoy changing value of any game or apps. :D
Android Apps Logo
I need help with my arduino robot
For the first android app, most probably is not compatible with your phone, since it is crashing:
Solution: get the source code and make it compiled to your Android phone version.
The second app is apparently working, but the settings and values are not matching the setting and values of the blue-tooth module.
Solution: Tray to change the setting on the bt module and debug it over the Arduino serial port until you get good values, then do the adaptations on the Arduino source code to match the android bt app.
Hope it helps
Jun 19, 2015 | Arduino Uno R3
How do I get unlimited gems
Download a modified version of your game, copy/cut your save file from android device and then delete the game, install the modified game on your android and out your save file back and you should have unlimited gems in whichever game this requires gems..enjoy ;)
Jan 30, 2015 | Android Apps
When download a application from market my mobile says tat tis application couldn't be installed on ur sd card or usb storage why is this happening
Android phones are smart it may be that your phone doesn't support the data that the application has to offer or it may be to big and you don't have enough memory or there is a security problem with the application
May 15, 2012 | Android Apps
How to undo or delete android games
Go to setting and then choose applications option. Then Manage application. Choose game u want to remove and click on uninstall. ur job is done
May 12, 2012 | Awesome Android Apps Android Apps
How to install a game on my samsung galaxy tab?
Well, there is a place called "Android Market" or similar.
If your desired game can be found there, simply download and install the game app and you can enjoy the fun.
If the game can't be found, or it requires a fee to play. You'll probably need to root the device. Here is a 1-click Android-Root solution for your reference.
Sep 07, 2011 | Samsung Galaxy Tab Tablet PC
256 people viewed this tip
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
