Tip & How-To about Miscellaneous
Application Testing different to Desktop Application Testing
Web Programs are typically organised on a server which we can access via a internet web browser, where as pc applications are set up on the client's machine.
This installation reveals a whole new examining challenges: Efficiency and Security examining become essential as the program is open to a wide viewers. Good design and functionality are also essential.Other key elements that come to play are examining on several internet explorer, several gadgets, re-direction and responsiveness.Also we should not forget about Javascript, CSS, Biscuits, W3C requirements, traffic tracking, third party labels examining, all of which are essential in Web Application Testing.
http://mobilelabsinc.com/
Miscellaneous Logo
How To Fix Google Chrome Error 105?
Error 105 indicates that Chrome can't find a DNS server.
Without a DNS server, a browser can't find a web page using a domain name (such as google.com) and therefore cannot surf the web.
If you have another browser, such as Edge, Internet Explorer, or Firefox and they cannot reach google.com either, then you are either not connected to a network with internet access or your browser has been hijacked.
If you are on a windows computer, use Windows+R or click in the Run box on your start menu and type cmd to pull up a command window. type >ping google.com and hit enter... if it pings the address successfully, then you have DNS and your browser has been clobbered.
Otherwise try connecting to another network, contact your network administrator, or examine your TCP/IP settings for your current network adapter and set your Preferred DNS server to 8.8.8.8 (google's DNS server) and the Alternate DNS to 4.4.4.4 (also google). This should give you access to the whole internet via domain names.
Sep 21, 2017 | Google Computers & Internet
What is the difference between VPN-connection and Proxy websites?
While both a Proxy and VPN service will re-route your internet traffic and change your IP, they function slightly differently.
Think of a Proxy as a Web Filter. The proxy settings are applied to your internet browser whether you're using MSIE, Chrome, Safari, Firefox, Etc. When browsing the internet through a proxy server, all benefits with that server are used, for example, (Security, Speed, and Geographic Location). The proxy will only secure traffic via the internet browser using the proxy server settings.
Unlike a Proxy, a VPN service provider(Virtual Private Network) encrypts all of your traffic, replacing your ISP and routing ALL traffic through the VPN server, including all programs and applications. This also will use all benefits of the VPN server such as (Speed, Geopgraphic Location, and Security).
The VPN can be easily connected or disconnected with the click of a button.
In conclusion, a proxy server is completely browser based, and is not as compatible with certain web pages that use non-browser technology such as: Comedy Central,Zatoo, Fox OD, and Sky Player. However, a VPN will work with ALL internet based services, but will offer less choice on which applications will get run through your ISP, as with the VPN, everything is routed through that server when connected.
So, you can get VPN services from sources like HideMyAss, Super VPN, etc., Once you have enabled a VPN service, you can visit IP-Details.com and have an IP lookup to ensure the change in your IP address.
Jan 21, 2015 | Computers & Internet
reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
I am unable to access my e-mail. Error message
write to the provider and communicate the error code...at least for yahoo I managed to unlock in this way some mail addresses
but in theory it ok for all mail servers ///
Oct 07, 2009 | Computers & Internet
105 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
