Tip & How-To about Miscellaneous
Mobile automation testing tools
Http://mobilelabsinc.com/
The means of automation are usually chosen subjectively depending on project needs and application type. Among good paid automation tools available today are Ranorex, Silk Mobile, SeeTest, etc. There are also worthy free tools like Appium, Robotium, KIF, Calabash, etc., but using these requires certain coding skills such as Java or Ruby.
Miscellaneous Logo
What is the difference between Manual vs. Automated Testing?
Difference between Manual and Automation Testing is the pillar of Software testing, because whole testing is based on Manual and Automation Testing. In a project you can do either Manual or Automation Testing and you can also do both Manual and Automation Testing simultaneously.
Complete Difference between Manual and Automation Testing
Manual Testing Automation Testing 1. Manual Testing is a process which is done manually. 1. Automation Testing is a process which is done by the help of automated tools. 2. All the famous phases of STLC like test planning, test deployment, result analysis, test execution, bug tracking and reporting tools are obviously comes under the category of Manual Testing and done successfully by human efforts. 2. In Automation Testing all the popular phases of STLC are done by various open sources and purchased tools like Selenium, J meter, QTP, Load Runner, Win Runner and so on. 3. Manual Testing is a start of Testing, without this testing we can't start Automation Testing. 3. Automation Testing is a continuous part of Manual Testing. 4. In Manual Testing testers are allowed to do Random Testing to find the Bugs. 4. In Automation Testing we always test through Running Scripts. 5. In Manual Testing we find more bugs than automation by Error Guessing. 5. In Automation Testing we test the repetitive functionalities of the application. 6. It takes lot of time. 6. It takes less time. 7. Manual Testing would be run sequentially. 7. Automation Testing is done on different machines at same time. 8. Regression Testing process is tough in Manual Testing 8. Regression Testing process is easy in Automation Testing by Tools. 9. It is not expensive. 9. It is expensive. 10. More testers are required in Manual Testing because in this testing test cases need to be executed manually. 10. Few testers are required in Automation Testing because in this testing test cases need to be executed by using Automation Tools. 11. It gives low accuracy result. 12. It gives high accuracy result. 12. It is considered as low quality. 12. It is considered as high quality. 13. In this Testing we cannot do batch testing. 13. In this Testing we can do multiple types of batch testing. 14. It is considered as less reliable. 14. It is considered as more reliable. 15. No need of programming in Manual Testing. 15. Need of programming is must in Automation Testing. 16. It is done without interaction of any Tool. 16. It is always done using tools.
Aug 24, 2016 | Microsoft Video Game Consoles & Games
sir i want uml diagrams for my project AUTOMATED TASK ALLOCATION AND MONITORING
Uml diagrams are very complex and detailed subject. Specially applying on a specific subject needs to know the details of the project. But as an approaching vision can easily be understood by looking selected examples. I think it can only be solved by the owner of the project. This link may be helpful for thinking how to and where to start.
I think it will a help you a little.
Mar 25, 2010 | Computers & Internet
can I email my projects if I am using MSN.Com email? how do I set that up in control panel?
  1. tep 1 Go to your e-mail program.
  2. Step 2 Click the New Mail, Write Message or similar button, depending on your application to create a new e-mail message.
  3. Step 3 Enter the address of the recipient in the To field.
  4. Step 4 Type a subject in the Subject field.
  5. Step 5 Add a message to the body of the e-mail as usual.
  6. Step 6 Click the Attachments button. Many programs have an icon of a paperclip for it. Also look for an Insert File or Insert Attachment option in the File menu.
  7. Step 7 Browse your files to find the attachment you want to send. You may need to click on a Browse or Find button to see your directory.
  8. Step 8 Click on the filename. If your program allows you to attach more than one file at once, hold down the Control key (or Shift key on a Mac) as you select another one.
  9. Step 9 Click the Attach Insert or Open button, depending on your e-mail program.
  10. Step 10 To send another file from a different location, click the Attachments but-ton again and repeat the steps.
  11. Step 11 Click the Send button when you're done.
Nov 15, 2009 | Broderbund PrintMaster Platinum Version 18
how can we prepare online shoping project using jsp
You can try online shopping website in ASP.NET.you can also make it by java. try to know about more making shopping project,many projects are available in Internet.
I give you some tips.
This is part of web application and to start with any web application follow these steps:
1) Understand what features that you would like to do in this project. (Generally this may involve whether to use payment process, indexing and so on ... if you want a plain vanilla kind of without many features then just ignore it)
2) Decide on the frameworks that you would like to use for your web application - Struts/Spring MVC/Hibernate/JSF and so on
3) Do a sample application using the framework chosen by you to increase your comfort level
4) Decide on technical environment - server/editor/database ... and so on
5) Design the application (at least decide on what screens and how the navigation should happen)
6) Develop the application
Sep 21, 2009 | Computers & Internet
125 people viewed this tip
Top Miscellaneous Experts
Gene Haynes
Betty Kent
Betty Kent
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
