Tip & How-To about Miscellaneous
SERVICE MANUAL
Http://manualslibrary.net/CREST-AUDIO-CA9-MANUAL-SERVICE.html
Miscellaneous Logo
ariston dishwasher flashing code a13
http://salvationarmynaples.net/readpdf/ariston-dishwasher-manual-l64.pdf
http://manualslibrary.net/ARISTON-DISHWASHER-MANUAL-OPERATION.html
These are the sites for two manuals on your machine. They are free downloads that can be read by any computer. I'm sure there is a code list in there somewhere.
Dec 10, 2016 | Dishwashers
smoke comes out from the switch and wont turn on ... there 2 amps make of ca9 and ca6 wondering if you guys can help
This is a very easy cheap fix, but since this thread is pretty old first make contact to help you out with this issue, common on CA series power amplifiers of Crest Audio.
Aug 12, 2011 | Crest Audio CA 9 2Channel Amplifier
why my crest audio ca6 has the lights clip signal
disconnect you load (speakers) power amp up. If this fault persists there might be a problemm with the amp
Apr 21, 2010 | Crest Audio CA9 Car Audio Amplifier
clip and protect LEDs but no speaker output
Protect is a mode that it goes into that prevents future damage, i would recommend replacing the fuses.
Sep 26, 2009 | Crest Audio CA9 Car Audio Amplifier
My CA9 has protect recurrent problems.
if you are bridged in parallel instead of in series the amp wont support the load so it turns the power protect on till the amp cant handle nomore then the amp will go if you have two subs bridged run them left speaker possative to to the amp possative for bridged mode then laft speaker negative to the right speaker possative then right speaker negative to your amp negative for bridged mode if you have them left and right speaker possative to amp possative and left and right speaker neggative to your negative to your amp thats parallel the ampwont support the 2 ohm load
Feb 08, 2009 | Crest Audio CA9 Car Audio Amplifier
94 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
