Tip & How-To about Amana Kitchen Ranges
HOW TO TIDY UP THAT UNSIGHTLY SILICONE SEAL AROUND YOUR SHOWER BASE OR ANY SILICONE SEAL ON CONNECTING EDGING.
1. BUY A 1/2" TO 1" WIDE WHITE PLASTIC FLAT STRIP ABOUT 2 MM OR 1/8" OR LESS THICK. OR BUY ANY PLASTIC STRIP AND CUT DOWN TO SIZE AS ABOVE.
AT THE BASE OF MY SHOWER WHERE THE BASE UNIT CONNECTS TO THE TILES THERE WAS A UNSIGHTLY SILICONE SEAL.
I GOT A LENGTH OF WALL CABLE CAPPING /WHITE AND CUT IT INTO 1" WIDE FLAT STRIPS OR YOU CAN PURCHASE FLAT PLASTIC STRIPS NORMALLY A COUPLE OF METRES LONG FROM YOUR LOCAL DO IT ALL SUPPLIER , CLEAN AND DRY OLD SEAL USING A HAIR DRYER ,
CUT ONE LENGTH AT A TIME, REMEMBERING TO ANGLE CONNECTING CORNERS, USE FRESH SILICONE TO RUN ALONG WHERE OLD SILICONE IS
PLENTY TO FILL IN GAP , NOW FIT PLASTIC STRIP AT A ANGLE ACROSS TILE AN BASE UNIT ,PUSH IN UNTIL SILICONE STARTS TO SEEP OUT OF EDGES, WIPE WITH A WET CLOTH TO REMOVE ANY SILICONE,
SO YOU END UP WITH A EASY TO CLEAN PLASTIC SEAL ANGLED AS /l AROUND BASE OF SHOWER.
WITH NO SILICONE IN SITE TO DISCOLOR. ALSO WORK TOPS TO TILES CUT SMALL STRIPS SAY 3/8" TO 1/2" WIDE ANY COLOUR. FIT AS ABOVE.
Kitchen Ranges Logo
I have a large gap to seal btwn tile and tub. Any suggestions?
how big is large ?
if it is over 1/2" but under 1" cut a slice of tile to fill the gap
if under 1/2 inch use a silicon sealer ( no more gaps) to fill the space
to get a smooth finish on the sealer use your finger --wet it in water or suitable applicator that is wet with water
once the desired finish is achieved , let it dry and it becomes water resistant
Nov 11, 2016 | Washing Machines
what is A3
As per ISO (International Standard Organization) A series cut sheet sizes, A4 is 297 mm long and 210 mm wide sheet. Equivalent size in inches is 11.69" long and 8.27" wide.
Nearest US size is Letter size which is 11.0" long and 8.5" wide written as 8.5x11.
Nearest Traditional British size is Quarto which is 8.0" wide and 10" long written as 8x10.
these are paper size.
Aug 18, 2012 | Sharp BR MX-6201N - 1-SD YLD BLACK TONER
no battery for simmons scope model no. 1057
This scope will use a 1.5 volt button battery that is 4.2 mm thick and from 11 to 16 mm wide. A thin rubber washer can be used with a V386 battery or a LR43. Both are 11.6 mm by 4.2. My scope came with a thin 16x12 mm ring made of plastic so that the battery would be held firmly into the center position.
After a close inspection, it is possible that a similar sized battery that is 3.6mm thick/thin might work also, but would have a shorter life due to less capacity.
I hope this is helpful. If not, I would be happy for you to sell me your scope for another gun of mine! :-)
carwhisperer1450@gmail.com
Dec 20, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
calibration strip location
I got my answer from a very helpful scanner expert from a posting on the newsgroup comp.periphs.scanners. The plastic piece went near the end of the bezel that holds the glass above the starting position for the scanning run. Once I knew the idea, locating where it went was easy because of small indentations in the bezel the shape and size of the plastic piece. Thanks.
Aug 07, 2008 | HP Officejet 5610 All-In-One InkJet...
MacBook opening screen leaves a one inch black strip on both sides.
use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Mar 21, 2008 | Apple MacBook PC Notebook
258 people viewed this tip
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
