Tip & How-To about Cooktops
Tube
Tube burning wont. however before nice like burning. hardship where?
Cooktops Logo
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
How do I change out the Switch on a gas cook top -Jenn-Air JGC9430ADS
if you mean the switch under the knob,
you can open up, drill, the switch and clean up and use it again, uless the copper parts are burned out.
to get to the switch, most likely have to unscrew all the screws holding the top and the bottom together, most likely the screws will be on the top, by the gas burner on each burner. and may need to check the sides for additional screws .
if you go step by step , its pretty easy.
maybe you should look up on you tube for demo.
Apr 19, 2013 | Jenn-Air Cooktops
westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
May 29, 2010 | Cooktops
I need a new gas feeder tube to the right front
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43634&diagram_id=762419#d762419
Copy and paste this link.
They have your parts in stock according to their inventory.
Jan 16, 2010 | Cooktops
what do I use to keep my stove top clean
Throw the burners in a large garbage bag and spray it with easy off oven cleaner. Seal the bag for a day and then rinse everything off. Clean the aluminum parts with a nice wire brush from the hardware store.
Oct 16, 2008 | Jenn-Air JGC8536 Gas Cooktop
233 people viewed this tip
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
