Tip & How-To about iCare Recovery Software iCare Data Recovery Software
Best Memory Card Photo Recovery Software
Generally speaking, after unexpected delete, shift delete, format, reformat, RAW file system error, not formatted or unformatted error, security wipe, factory reset, virus infection and more android phone memory card data loss problems, a phone memory card data recovery utility is what you are looking for to take deleted or lost android phone data back.
Hence, right now, go download and apply two or more memory card recovery programs to recover deleted or lost information from your android phone memory card with lowest cost.
Read More Android Phone Memory Card Recovery Information:
Memory Card Recovery Software Free Download:
Recover Deleted Files from Memory Card:
Computers & Internet Logo
pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i try to access my Trekstor Datastation maxi mu 400Gb, I had error that the drive is not formatted. And if I try to fix or retrieve the files with PCI file recovery or other software like it, i got a error Wrong disk parameters. Please i need help. I got there important information for me
it is difficult to recover it from that partition..use this software
"Recover My Files" if it is recover then ok otherwise use "Virtual Lab"
if it is not again recoverable then noway to recover. after all efforts one thing u can do is to quick format it and then try recover my files to recover from fast formated drive....but chances r very less something like wallpapers and songs can be recover.
Good Luck.
Hope the files will recover
Nov 24, 2009 | Trekstor Computers & Internet
RAW file system
RAW file system is typical of an unformatted hard drive and is the default state for most new retail drives because the manufacturers won't know which operating system their customers are going to put on the drive or use it in conjunction with.
Most operating system installations come with utilities to partion and and format new drives see fdisk from MSDOS (specifically versions 5 and higher) And MS Windows 3.1 through 95,98 and ME which all used the FAT32 file system as default and would partition and format during installation. Windows NT similarly would partition and format the drive during install to the NTFS system, as do all versions of Windows XP.
if you are not installing a new OS but setting the drive as a slave to a currently installed drive then you can use a program like Partition Magic or similar to detect the installed drive and partition / format it tou your requirements
Oct 08, 2008 | Computers & Internet
I:\ is not accessible the file or dir.is corrupted and unreadable
Hi and thanks for writing back. I found that since the drive turned to a raw that windows will not read it.I don't know why it turned from ntfs to raw but it did. so I downloaded the O&O file recovery trial ver.to see if I could recover the pics. and movies.It took 5 hrs. to run and it recoverd everything.now I have to buy the software. but I know it is still all there.this software will even recover reformatted drives.Anybody that gets the same error mess. look to see if your file system has changed.If so it looks like recovery software is the only way to go.I have other good info on this and other maxtor hdd I will check back on post and write if you have sim.probs.
Jun 30, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
144 people viewed this tip
Top iCare Recovery Software Computers & Internet Experts
David Payne
David Payne
Are you an iCare Recovery Software Computer and Internet Expert? Answer questions, earn points and help others
