Tip & How-To about Miscellaneous
New HP Sprocket Photo Printer
Using the HP Sprocket Photo printer, you can easily print photos from your tablet or smartphone and post them as soon as possible. The Sprocket, a pocket-size printer is specially designed to print photos directly from your smartphone. It connects to your devices via Bluetooth, and usages the Sprocket application, which is available both Android and iOS. The app lets your print photos from your smartphone's storage, Flicker, Instagram, Facebook account, and more. Also, if you want to purchase this printer, but you have some sorts of queries, then you can contact the HP customer care number to get prompt resolution.
Main features and functions:
Ease-of-use: Printing of the social media photos from your smartphone is not an easier task. This printer doesn't require any configuration or setup; you just need to download the Sprocket App, and you will be able to use it. But you also need to open the Bluetooth to make pairing with the Sprocket. Connect your social media account for the app and directly turn these photos into colorful prints.
A Social on-the-go printer: The Sprocket uses smooth Bluetooth connectivity; thus you can use it at events and parties and can print your long-lasting moments from your tablet or smartphone as well as share them directly to the printer on social media.
Photo Editing: The HP Sprocket app doesn't just print off your photos; it also allows you to edit or customize these pictures before you print. You can add borders, fun text, emoji's, and more. Interestingly enough, you can insert a pop of personality for stickers and snapshots that are completely different to you.
Prompt snapshots anywhere:
The HP photo printer was designed to use wherever you do. It's very light and easily fits into the bag, thus you can make 2×3-inch stackable snapshots at any time when the moment strikes. The battery is capable of printing 50 different images, and even you can charge it using any of the Micro USB cable.
All in all, the HP Sprocket printer is a fun, handy method to create physical copies of all your precious memories. It's amazing to use and allows you to edit your images just the way you wish. If you're already using a smartphone, you can save your money from obtaining something like that instead of a combination of printer and camera. For everyone else, this is both fun and affordable. If you are seeking for HP customer service to clarify your concerns, you can call at the HP support phone number and resolve them promptly. Hewlett Packard HP Customer Tech Service Support Number
https://medium.com/@contactforhelp2/new-hp-sprocket-photo-printer-94f7b6aa3e53
Miscellaneous Logo
paper jam in hp psc 1210v all in one printer/scanner/copier
Check for any obstacle in the Outlet of Printer or Paper input area
Which dp size paper u r using try with different photo paper
Jun 01, 2010 | HP PSC 1210v All-In-One InkJet Printer
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
When I'm printing a photo on HP photo paper, it prints fine 3/4 of the paper, but the last 1/4 is purple. The cartridges have been changed several times to see if thats the problem. What can I do?
it is possible that the head of the printer is dirty or the head is damaged, are you using unversal catriged or the orginal if you using refills it is possible that you printer head has been damaged
Oct 08, 2009 | HP Photosmart D5160 InkJet Printer
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
HP PSC 1350 Photo Printing (Glossy Paper) Pront Quality issue
keep checking the HP site for an updated Driver for your printer, but why not use an online photo printing service like Walgreens or Walmart, You can't possibly print photos at home cheaper than they can, and this way you get actual photographs back.
Dec 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
157 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
