Tip & How-To about Pool & Spa
Solving Salt Water Pool Problems
The big problems with salt water pools is actually the salt in the pool water itself. Salt water chlorination has many benefits over standard pool chlorination methods, but with a salt in the pool system there are significant drawbacks, hidden expenses, problems, and potential dangers. The best way to enjoy salt chlorination is to get the salt out of the pool. The Chlorine Genie Pool Water Management System does just that. In fact the system can produce and take care of up to 5 important pool chemicals for you. If you are fed up with salt water pool problems and ready for the cutting edge in pool water sanitation, check out the new advantages of Chlorine Genie's Chlorine Generator Technology.
Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Check out the Pool System Videos on YouTube at: Chlorine Genie
Get Social and Join the Pool Party at: https://about.me/chlorinegenie Chlorine Genie on about me
Pool & Spa Logo
Is a saltwater swimming pool bad for you?
only if you live in it full time without showering in fresh water after .then you will get crusty.
Feb 13, 2016 | CircuPool Salt Water Pool System
just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to resolve this problem or will just shut down pool. Thanks
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have added two bags of salt total since we filled the pool and there has been no indicator of low salt. We are now running the filter continuously but it doesn't seem to be changing. Any suggestions?
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
102 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
