Tip & How-To about Ovens
Kitchen Appliances Maintenance Tips
All natural oven cleaner
  1. gently scrap of the burned on food with help of plastic scraper.
  2. create a paste of baking soda with water. 5 table spoon of water per cup of baking soda.
  3. wipe on to the top and inside the stove and let it rest for 12 hours.
  4. use a damp sponge to wipe of the dried paste. Use vinegar to make the job easier.
Ovens Logo
No manual. Hit the clean button and 15 minutes it caught on fire. Hit the cancel
It probably caught fire because to much crud was built up inside probably from not cleaning often enough. I assume there were not flames but just a lot of smoke, try again but watch it carefully. Some ovens are damaged by oven cleaner so I would get a manual first to be sure using that would be OM.
Here are some links that may help:
How to Clean Oven Naturally with Baking Soda Tutorial
How To Clean an Oven With Baking Soda Vinegar Cleaning Lessons from The...
Mar 02, 2015 | Ovens
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Jan 01, 2014 | Ovens
wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
335 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
