Tip & How-To about Belkin F1DK102U 2-port KVM Switch
Remember to check the cables!
For me this device kept doing the switching back and forth thingie until I noticed that one of the display cables was bit out of it's place.
Tightened the screws and Voilá!
All these things with lotsa wires on them... Always remember to check the cables!
Belkin F1DK102U 2-port KVM Switch Logo
how do you replace a neutral safety switch on a saturn sl1 2001
It 's a Transmission Range Switch , it tells the pcm more then just park or neutral positions !
Transmission Range Switch Replacement
Ensure the ignition is OFF.
Remove the air cleaner and duct assembly. Refer to Air Cleaner Housing and Duct Assembly Replacement in HVAC.
Disconnect the transaxle range switch harness connectors.
Place the control lever in the full clockwise position.
Notice: If manual shift shaft is rotated excessively, internal damage to the transaxle range switch may occur.
Prevent the manual shift shaft from rotating by holding the control lever while removing the retaining nut from the manual shift shaft. Remove the control lever.
Remove the 2 switch-to-transaxle case bolts and remove the switch.
Install the cable to the control lever and adjust the cable. Refer to Shift Control Cable Adjustment .
Before tightening the transaxle range switch-to-case bolts, proceed to the Adjustment procedure.
Adjustment Procedure
Important: While adjusting the transaxle range switch, always rotate the switch towards the engine to achieve continuity. A diagnostic trouble code DTC P0706 could result if this procedure is not followed.
Important: Digital volt/ohm meter (DVOM) with audible continuity test is preferred. Do not stick the probe in the transaxle range switch terminal hole; use male terminals on the transaxle range switch or faulty readings could occur.
Place the transaxle in Drive (D). Use an ohmmeter or continuity tester to check for continuity across terminals on the selector switch. Rotate the transaxle range switch from the left fender towards the engine until continuity is achieved.
Notice: Refer to Fastener Notice in the Preface section.
Tighten the switch-to-case bolts. After switch-to-case bolts have been tightened, check continuity.
Tighten
Tighten the transaxle range switch-to-case bolts to 14 N·m (10 lb ft).
Connect the transaxle range switch harness connectors.
Install the air cleaner and duct assembly. Refer to Air Cleaner Housing and Duct Assembly Replacement in HVAC.
Using a scan tool, ensure each gear position reads correctly while manually moving through all gears.
Dec 15, 2016 | 2001 Saturn SL
The video 1 and video 2 display flashing simultaneously back and forth...cant play dvd cause it continually switches back and forth
Try a different resolution setting.
You can also try playing the dvd into another device to confirm dvd works fine.
Check output\mode of device as well.
I assume, you inserted another dvd and it worked fine, then you inserted the "questioned" dvd is it flashes back and forth.
Try another video mode or setting change on device.
Jul 22, 2014 | Televison & Video
The drain hose on my maytag centennial was leaking where it leaves the pump so I pulled it out and tightened the connection, replaced the back, and moved it back into place. On the next load, it sensed, filled with water and stopped. Now it won't drain, sense, or anything else! I removed the clothes, still nothing. What do I do next?
You may have interrupted the drain cycle so you may need to empty all the water out to reset sensor.maybe move machine to w/h door and lower the drain hose outside until most of water is removed then start wash again from scratch. Or your out of balance switch activated if you tilted the machine, if so reach in the back at top of bowl and you should find a lever arm, jiggle gently back and forth then try the machine again.
Oct 25, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
We have a DENON L.C twin transformer amplifier PMA-735R that has an input selector that freaks out now and again. Recently it has gotten worse, it just goes back and forth between tuner and cd etc. for minutes on end, but sometimes won't do it for weeks. Contact cleaner seems to be the solution for alot of these type of questions, did that actually work out?
Hi Readers to of Fixya,
This entry is January 22, 2016.
I own a Denon PMA 735R which I bought new in 1999, it is very good Amp; starting about a few years ago the input selector would occasionally randomly jump from CD to Phono to Tape etc., but would always end up back at CD so it was not terribly annoying until a few days ago when it started happening all the time. I am a very knowledgeable electronics person (I built musical keyboards at one time) so my thought was just that it was a dust problem and I started with that premise. I fixed it using an Electrical Parts Cleaner spray and here is how I did it:
I unplugged it, removed the CD input RCA cables and removed the L & R speaker cables and took it off its shelf and set it on a towel on my soft sofa; I removed the casing by unscrewing four big silver screws on the sides (my model is silver) and the three small black screws on the back top; I removed the Input Selector indicator knob on the front and the Record Out Selector indicator knob and the Volume knob, I then removed the small nut that holds the three of them tightly in place to the front panel; I then stood it on its back so that the front was facing up; I then sprayed my Electrical Parts Cleaner spray into the Input Selector indicator post liberally and then put the knob back in place and kept turning the indicator back and forth for a few minutes to work the cleaner inside the post down into the circuit board connection; I did the same with the Record Out Selector indicator post and I did the same with the Volume post; I then put the small nuts back on the three posts and tightened them; I then put the knobs back on the three posts; I then stood it back on its normal upright position and put the casing back on and then the screws; I placed back on its shelf and hooked up the cables and switched it back on and played my CD's, it has been working perfectly fine. The whole process took less than 30 minutes.I hope this helps.
Feb 20, 2012 | Denon Audio Players & Recorders
how do i replace the ignition switch
FIRST TURN OFF RADIO.DISCONNECT THE NEGATIVE BATTERY CABLE,THEN THE POSITIVE BATTERY CABLE.WAIT 20 MINUTES. UNTIL AIRBAGS DISCHARGE.TURN THE IGNITION KEY LOCK CYLINDER TO THE RUN POSITION.REMOVE THE CENTER TRIM PANEL AND THE DRIVER SIDE KNEE BOLSTER.UNPLUG THE IGNITION SWITCH ELECTRICAL CONNECTOR AND REMOVE THE SWITCH RETAINING SCREWS. DISENGAGE THE IGNITION SWITCH FROM THE ACTUATOR PIN AND REMOVE THE SWITCH FROM THE VECHICLE.MAKE SURE THE ACTUATOR PIN SLOT IN THE NEW IGNITION SWITCH IS IN THE RUN POSITION.A NEW REPLACEMENT SWITCH WILL BE SET IN THIS POSITION.PLACE THE NEW SWITCH IN POSITION ON THE ACTUATOR PIN AND INSTALL THE RETAINING SCREWS IT MAY BE NECESSARY TO MOVE THE SWITCH BACK AND FORTH TO LINE UP THE SCREW HOLES.WHEN CENTER TRIM AND KNEE BOLSTER BACK IN PLACE.CHECK FOR PROPER OPERATION OF THE IGNITION SWITCH IN THE LOCK, START AND ACCESSORY POSITIONS.
Feb 14, 2011 | 1999 Ford Expedition
1,098 people viewed this tip
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
