Tip & How-To about Miscellaneous
Replacement Buehler Omnimet Joystick pots
Noisy x-y joysick pots are NLA from Buehler for this hardness tester. They say buy a new unit for $60,000. The exact part is DigiKey stock # CT3064-ND costing about $4, you need two. It is a 100k linear potentiometer part # 450T328F104A1A1.
Miscellaneous Logo
394-1128A 1 - Coil Assembly, NLA
This is the coil for an older magneto-based Kieckhaefer distrubutor, right?
Not avaiable anymore through Mercury themselves, but there are some new old stock parts available on e-bay...
Dec 29, 2013 | Mercury Marine 394-1128A 1 - Coil...
where can i buy extra pot for ge 3 combo crockpot
In the manufacturing world most times they don't bother trying to stock parts like that. You just have to buy another used or new unit or buy another model
Dec 02, 2013 | GE 106851 6-Quart
I need a volume control pot. for a RCA WHP150C 900MHz wireless headphone. I cannot find a circuit digram nor do not know how to order it by part number (since I don't have the circuit diagram). I need a part number and a source where I can buy ONLY the volume control part. Thank You, Arthur B. Cruz/ arthurbcruz@hotmail.com
Hello Arthur.
If the pot has an engraved / embossed / screen printed value on it you may also be able to buy an exact replacement from your local electronics component stockist.
Otherwise take it with you as a sample.
Pots are standard values, so most component stores will stock your one.
This will be cheaper and speedier than ordering one.
Regards, Clive.
Nov 21, 2017 | RCA WHP150C Consumer Headphones
The handle came off my smart pot lid. We glued it back on, but it came off a second time. Can I replace the lid? Better yet, how can I attach the handle?
I sent an email to them this website
"http://www.jardenstore.com/
I had the BEST experience. The same thing happened to my 4 qt slow cooker, since they did not have my lid in stock, they sent me a brand new unit at no charge!
An alternative is to buy a cabinet knob t lowes with a high temp washer.
Mar 14, 2011 | Rival 38601 Smart Pot 6-Quart
sr-16 drum machine need part
The pot is PROBABLY an audio taper so check the suffix on the old one.
Many pots you can find at Digikey.com or Mouser.com.
You MAY have to cut the shaft length
For an exact replacement you will probably have to go to Alesis.
4.7 K is NOT a standard value for pots. 5K ohms is.
Apr 04, 2010 | Alesis Sr 16 Stereo Drum Machine
181 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
