Tip & How-To about Miscellaneous
How to Avoid an HP Photosmart Printer Cartridge Issue
Overriding Expired Ink
Every HP printer that has an expired-ink overrides method, with the Photosmart series, delivers step wise instructions to implement the override in at least one of three ways. You may see a built-in screen or a warning message, recognizing both the control-panel and the problem keys to press to do the printing. If the printer lacks in the display, it may show a flashing indicator light pattern that position of the keys to press. The manual guide that escorts your HP Photosmart printer may also offer instructions to perform the override.
Bypassing Ink cartridge Failure
If you are printing with outdated cartridges, your printer may face an ink system failing that lacks any recognizable override procedure. Many Photosmart printers have a hidden restoration series that can bring your device back to life. The key-press process included a composite ink initialization where you need to press multiple keys and unplug the printer from the power outlet for 30 seconds. When you connect the printer back, it executes a one-time process that eliminates the hardware failure.
Other Considerations
Sometimes, refilled and remanufactured ink cartridges include an appealing bargain when you relate their more modest cost to the new cartridge price. In such situations, both you can consider purchasing a refill kit and renewing your cartridges on your own, or buying from a refill service, you need to balance the investments against the prospect. Just like that, overriding the expiration dates on ink cartridges may seem a money-saving suggestion, unless and until it negotiations the printer working life.
However, if you are having the HP printer ink cartridges issues and looking for the quick solutions, it is highly suggested to call on the HP printers technical support number listed in Contactforhelp and get quick assistance.
Miscellaneous Logo
how to hard reset hp photosmart 8250?
To do a hard reset:
1. Make sure the printer is on.
2. Pull the power cord from the printer.
3. Pull the power cord from the wall.
4. Wait 30 seconds.
5. Plug the printer in and turn it on.
Got these instructions from here: https://h30434.www3.hp.com/t5/Inkjet-Printing/Overriding-Ink-Expiration-Issue-On-PhotoSmart-8250/td-p/1943075
Apr 24, 2017 | HP Office Equipment & Supplies
i bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
can't print on 8250 photosmart printer
See http://www.hp.com/pageyield/articles/us/en/InkExpiration.html on how to override error.
Apr 19, 2009 | HP Photosmart 8250 InkJet Printer
Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Feb 15, 2009 | HP Photosmart 8250 InkJet Printer
85 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
Philippe Dekyvere
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
