Tip & How-To about Cameras
Obtaining help from Fixya
Fixya would very much like to assist all enquirers. However, there are things that can be done to ensure that the correct group of people attempt to provide responses.
1) Make sure you are posting in the correct forum.
2) Be specific in your enquiry - remember that although you know what equipment you have, we do not, so give as much detail as possible, please. At the very least the make, model number, any accessories that may contribute to the problem, and finally full details of the problem itself.
3) If you require a manual for any equipment, don't forget that you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
4) Fixya does not provide spares or accessories for any equipment - if this is what you require, try the manufacturer or importer's website, or else any on-line shopping service.
5) Please remember that Fixya answers are provided by people such as yourselves, who are willing to share their knowledge and experience. You expect a polite response to your queries - we appreciate politeness and thanks shown to us.
Cameras Logo
no sound coming frow soundbar
Been there, done that. Check to ensure input is on the correct channel. I spent weeks trying to resolve the same issue and found that the connections that were "as they should be" were not correct, so double check connections as well. If all else fails, contact manufacturer for assistance. (I know that is a hard thing for a guy to do)
Dec 31, 2014 | Audio Players & Recorders
fixya posted my question in the wrong topic how can I fix it?
Hi There,
We are unable to change the category of your question, we suggest that you try to post your question again and ensure to review it before clicking submit to ensure that all the details are correct, once you have done so you can let us know and we will remove the question that is wrong.
FixYa Support Team
Mar 22, 2012 | FixYa Service
blue screen with no picture also lite lines
This is one of a group of sets with bad picture tubes, I can tell you how to attempt to adjust manually to correct it.
Can I assist here?
If this helped comment and rate this solution as very helpful as I do this here for free.
SD TECH
Sep 11, 2010 | Sony KP-57WV600 57" Rear Projection...
1996 dodge ram. Vehicle runs hot. I have replaced water pump, thermostat, coolant temperture switch , clutch fan. checked radiator for flowing properly also had block tested for blown head gasket.
Hello there"
sounds like you have done a lot with this there is a few things that you can do to ensue every thing is running right.
first if you can get a handheld thermal gun and check the temperature at the temp sensor on the radiator or block then see what it reads compared to the guage to ensure the guage is correct.
next check the temperature at both the top and the bottom of the radiatoer if there is a big difference in temps the radiator is partially blocked a radiator will increase 30 to 100 degrees if the radiator is 20 percent blocked.. also check to ensure that the radiator hoses are not collapsing.
Now ensure that you are not gettin air in the system by way of the water pump gasket or by loose hoses ok?
and finaly check to ensure that the heater core is not leaking and drawing air into the system or is clogged this will make a vehical give the overheating symptom also ok?
Let me know how this is going
Best regards mikle
An
Jul 07, 2010 | 1996 Dodge Ram
452 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
