Tip & How-To about Canon PIXMA MX922 Wireless All-in-One Color Inkjet Office
Printer MX922 Error message 1311 paper jam
Load a piece of thick paper manually as far as possible without too much force , for example photo paper and press the resume button or turn power on(may be different button on different models) a few times to the printer picks up the paper and puts it through the machine. THIS WORKED FOR ME!! YEA!! It worked and I didnt have the upper cassette loaded either. Canon told me to take it to the service center-- I had a small 3 by 5 piece of paper stuck that I could not see anywhere with the ***** eye. Never again will I do that.
Canon PIXMA MX922 Wireless All-in-One Color Inkjet Office Logo
printer will not work after paper jam fixed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
alternative :
Jun 09, 2009 | HP Photosmart C6280 Printer
paper jam flashing rx 425 did me best no paper in jam cant p0rint nothing
alternative :
Apr 22, 2009 | Epson RX620 All-In-One InkJet Photo...
paper jams when i use 220gsm paper
hey, try this:
alternative :
Dec 28, 2008 | Epson Stylus Photo R340 InkJet Printer
Paper jammed. Remove jammed paper and press the printer's RESUME button.
give this a try
alternative :
Dec 15, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
522 people viewed this tip
old marine
old marine
