Tip & How-To about Miscellaneous
Making it easier to answer questions
When you ask a question on here, it is always a good idea to mention your geographical location as well as give specifics about the question you're asking. Example "Does my car have a radiator?" does not make it easy to answer. If you ask "I have an original 1975 model VW Beetle 1.3 and I live in Mozambique - does my car have a radiator?" Makes it a lot easier to answer
Miscellaneous Logo
I am looking for a manual for a Husqvarna Viking 350 computer sewing machine. Where can I get one?
One place you might try would be at www.sewingpartsonline.com Although I didn't see the manual you are looking for advertised, (they did have a 350 manual), they also said to send an email to info@sewingpartsonline.com and ask for your specific manual. Also, you might want to check this website: http://www.tradebit.com It looks like they sell all sorts of manuals. I did find your manual, but putting the machine name in the search box. Of course it's always a good idea to keep an idea on eBay. I checked today but didn't see one, but you just never know. I checked on Amazon, and they had some parts, but no manual. But in the ads at the bottom of the page, they did recomend the first site I mentioned. Good luck!
Mar 04, 2011 | Husqvarna Prelude 370 Sewing Machine
what is the original cartridge specification for this model printer
Please mention always the Make/model of the product/device for which the question is posted so that we at fixya can give you a good solution.
Jan 10, 2011 | Office Equipment & Supplies
gramine gps is locked with a pass word.
Thankfully the solution is very simple to your problem. The only way for the Garmin to accept a setting of a password is if you also define a secure geographical spot right after the PIN code setting.
If no safe place is defined, the lock will not engage and the PIN setting attempt is void. So if it is locked it means your daughter has stored a safe location as well (you just click ok so it is easy also for a 3-year old).
At this geographical spot the GPS unit will be unlocked, and you will be able to change the PIN code to your liking or remove the lock.
So all you need to do is to recollect the specific geographical place your daughter may have played with your GPS, bring it to that place and switch it on: no PIN code is asked for when you found the correct spot. You may need to wait a few minutes for the unit to locate satellites, then it should unlock.
Jun 03, 2009 | Buck BENNETT DVD GARMIN NUVI 750 760/770
TCM Digital Watch
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Mar 05, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Basically because network file access to files on local networks (or geographically convienent locations) can speed access and or distribute network load this feature supports the creation and maintenence of multiple copies of data to facilitate timely access for a geographically distributed set of users. Depending on the size and user requirements this could be as close as replication between two buildings for higher volume use or as far as Europe or Asia for lower volumes of use to minimize internet traffic on could be relatively narrow and costly communication links between the continents.
Dec 15, 2007 | Microsoft Windows Server Standard 2003 for...
76 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
