Tip & How-To about Saeco Coffee Makers & Espresso Machines
Top cover closing not detected
The top cover of the Saeco Ideo Giro has a magnet in the cover and a sensor sticking up in the bean hopper that lets the machine know that the cover is closed. The sensor is in the front inside the hopper, sticking up but covered by the clear plastic hopper. My sensor slid down a quarter inch so that closing the lid wasn't detected, and the coffee maker would refuse to operate.
I fixed this by removing the hopper, sliding the magnetic sensor back up, and replacing the hopper. The hopper is held in place with a single screw with a hex socket. You have to nearly empty the hopper to see the screw, between the sensor and the grinder. The probe slides freely, so you can just push it up a bit, and the wires that are attached hold it (loosely) in place. When you put the hopper back in place over the probe, it'll push the probe down a bit, but as long as the probe is touching the hopper it'll work fine.
Credit for Saeco/Philips tech support for telling me that the hopper was easily removable.
Very easy repair. The hardest part was finding a screwdriver that would fit the screw. My hex keys - I tried both metric and english units - wouldn't fit, but I found a small standard screwdriver that worked, though I had to be careful that it wouldn't strip the hex socket.
Coffee Makers & Espresso Machines Logo
how do i change grinder setting while its running
I don't believe you can. There is a switch that turns off the grinder if you remove the lid to the bean hopper. The grinder adjustment is under that lid...so, unless you bypass the switch in the lid (which can be done) you cannot get access to the grinder adjustment.
-doc
Jun 26, 2014 | Saeco Odea Giro Plus Coffee Maker
the bean grinder doesnt grind, only water comes out
If it is working before, probably the coffee chute is clogged up. You can remove the bean hopper and see where the coffee drop into the brew unit.If the chute is still attached just clean the blockage, if it is broken you will have to remove the grinder and replaced it.
Jan 17, 2010 | Saeco Odea-Giro Espresso Machine
Saeco Odea Giro - alarm light continually slow flashing
I had the same problem. I filled everything up and closed it then took the hopper top and placed a small magnet that fit the circumference of the hopper sensor (I took one off of a refrigerator magnet and it fit down into the sensor) and it immediately went green. Hope it works for you.
May 02, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Mar 01, 2009 | Saeco Odea Giro Plus Coffee Maker
309 people viewed this tip
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
