Tip & How-To about Miscellaneous
Steel Tube is an integral part of the tubing systems. Tube systems around the world involve connections which are provided by tube fittings. Steel Tube is consumed in bulk and provide for onward transmission of liquids and gases.
Steel Tube are designed keeping four aspects in mind:
Steel Tube Manufacturer are designed to have the highest Pressure rating which defines the maximum pressures the tube is designed to withstand.
Tube are also designed to have high vacuum which is the maximum vacuum pressure that can be created in the tube.
Tube are designed on bend radius. The Minimum bend radius is a rating based on the acceptable amount of deformation the tubing cross-section can undergo.
And finally the most important aspect is the Temperature range, which defines the full range of various temperatures that the tubing is designed to operate within.
Tube can be connected to tube fitting by swaging the ferrule to the nuts and tubes.
