Tip & How-To about Miscellaneous
Steel Pipe Manufacturer
Steel pipes are long, hollow tubes that can be used for a number of purposes. They are an integral part of the piping systems. The first methods for producing steel pipe were introduced in the early 1800s, and they have steadily evolved into the modern processes we use today. Pipe systems around the world involve connections which are provided by fittings. Steel pipes are consumed in bulk and provide for onward transmission of liquids and gases. They can be connected to fittings by welding and the structure is supported by connection of flanges. Steel pipe Manufacturer available in two types: Seamless Steel Pipes and Welded Steel Pipes. For both types we first cast raw steel into a more workable starting form. We then make it into a pipe by stretching the steel out into a seamless tube or by forcing the edges together and sealing them with a weld. We manufacture our steel pipes in all sizes from ½ to 48 and our steel pipes also have phenomenal strength and flexibility. Other than that we also use only very high quality coating material which results in getting an exceptional end finish.
Miscellaneous Logo
Why are the ice cubes from the ice maker hollowed out in the middle?
in the ice maker there is a series of small pipes about an inch long emersed in a tray of water,the gas flows throught these pipes frezzing the water making the ice and thats why its hollow in the middle
Aug 26, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
mitsubishi montero 2003 leaking anifreeze in the rear
There is a set of two steel pipes that carry coolant/antifreeze to the rear mounted heater core for heater operation. These steel pipes/tubes rust out, and you end up with a coolant leak. Mitsubishi has superceded the steel tubes with aluminum tube set. Not an easy job to replace the two pipes since they are routed over and around a few items under the vehicle before attaching to the heater core at the r/r of the vehicle.
May 04, 2012 | Mitsubishi Cars & Trucks
171 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
