Tip & How-To about Sharp Office Equipment & Supplies
I had worried that either there was a small piece of paper stuck somewhere deep in the mechanism, or else that a part was failing. I could clear the error by opening and closing the right side panel, but as soon as another page printed, the same error would occur.
When the "Clear Paper Path" error reliably comes up on the AR5516 after one page has printed, the problem is most commonly with a small plastic arm inside the right side panel. The plastic arm may become dislodged during a paper jam, during moving, or other jostling. The solution is to gently force the small plastic arm in place. The reason this causes the error is that the very right end of the plastic arm tells a sensor the previous page printed OK. If the arm is bent or partially dislodged, the arm's end is not where it is expected to be, and so the "Clear Paper Path" error is flagged. Opening and closing the right side door temporarily fixes the error because the motion of the side door opening and closing will often (about 50% of the time) temporarily move the arm's end into place.
clear mistfied b, what it mean please??
it means that there is a paper jam in the machine. if the paper is not visible from the side cover that means that a small piece of paper is stuck somewhere.
Dec 24, 2010 | Ricoh Aficio 1018D Copier
The machine keeps saying paper jam, there is no paper in there. I do not know how to clear it. I've pressed cancel numerous times.
Most likely there is a small piece of paper still stuck in the path somewhere. This happens often when you remove a jammed sheet. Sometimes a piece of it will rip off and remain stuck in the path. Try looking closely
Aug 25, 2010 | Office Equipment & Supplies
jam msg will not clear ? no paper in path?
when you removed the paper, a small piece might still be stuck somewhere or the sensor might have remained in the on position.
May 19, 2009 | Dell 1600n All-In-One Laser Printer
Brother MFC-235C will not clear paper feed fault
Most common cause of this in any printer is a tiny fragment of paper stuck in the sensor somewhere.
If you have powered off and back on without clearing the fault, then look hard (with a torch/flashlight) for small fragments of paper stuck in the mechanism.
Sep 09, 2008 | Brother Office Equipment & Supplies
lexmark x4270 paper jam
Have you looked inside the roller assembly. More often then not a small piece of paper will get stuck deep inside the roller assembly. This will lead to paper jam errors. Inspect more closely. You will probably find some tiny tidbit somewhere.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
442 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
