Tip & How-To about fedora Linux Operating System
AFTER UPDATE problem MANJARO LINUX between 15 and 22-09-2016
Dbus problem after update Manjaro linux system ffor those who have manjaro
22-9-2016 having an update i found a problem with starting with root privileges from kde desktop kuser and krusader and more tools that will not starting up.
all problems with dbus from terminal you can start up and export $(dbus-launch) and after you can start krusader with root privileges and also from the startmenu also kuser part of kdeadmin after export $(dbus-launch) froma terminal.
But i have read much stories of other linux tools and some of them removed idden file .kde4 so it will return with system defaults back , andsome of them have luck a time of 2 years ago , but now its 2016 and Manjaro is a very special and good stable linux BUT nothing was started with root privileges from the kde desktop like krusader or kuser and other tools for root sudo also ot even . there was 1 little problem that was a part and that was the dbus session....... so start your konsole and sudo pacman -S dbus-x11 and you will see a conflicting package dbus arrived thats installed ?? it asked you to remove dbus and say yes so dbus out and dbus-x11 installing and after that it works al as before correct .
perfect.
fedora Linux Operating System Logo
DOES WEB CAMERA BILTEMA 24-742 WORK WITH LINUX
Try it with MANJARO LINUX is likely the one that support it otherwise Opensuse, Fedora, or Mint
Sep 19, 2016 | Computers & Internet
HP Compaq 6910p overheats and shutdown
To much dust in the cpu-fan or gpu- fan or convex topped bulget or leaking capacitors inside
Apr 19, 2014 | HP Compaq 6910p Notebook PC PC Notebook
Being an Hp, I would suspect the GPU. Heat damage will make the CPU work very hard and it in turn will overheat. Unless the heatsink compound has lost its usefulness. Between the CPU and the heat sink.
i have deleted the webcam-driver of my Chiligreen Platin C7 laptop. couldn't find it on the web..
Try to load a linux live dvd Fedora MANJARO or some modern distro or a thumbdrive with the live distro and boot from dvd or from usb if a live thumbdrive.
from start go to system and then the info Center to look about the hardware what kind of chipset is used its likely it works in multimedia guvcview or other media in linux the chipset can sometimes find in other drivers from different brands
Jan 15, 2014 | Computers & Internet
235 people viewed this tip
Top fedora Computers & Internet Experts
alex metro
alex metro
none
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a fedora Computer and Internet Expert? Answer questions, earn points and help others
